The owners manual for an '83 says to tow in gear, but transfer in Neutral. And.. after every 200 miles start the engine to circulate the oil in the transmission.
I flat tow my about 10000 miles per year behind my motorhome, but there used to be a place in LA that did a mod for 2 of the gears that basically sling the oil and save you from that 200 mile chore. Unforetunatley they don't make that mod anymore .
For short flat tow trips I used to do what TexasAg suggested. For the long cross country trips i would just pull the rear drive shaft.
Other issues, you have to work out rear tail/turn lights on the Jeep. I used to have a trailer pig tail at the front of the Jeep which then ran to the back corners. At the tail lights I had a set of bullet connectors. During normal driving of the Jeep I would have the tail lights hooked up to the Jeep's harness. When it came time to tow I would disconnect the tail lights from the Jeep harness and plug them into the "trailer" wires. Hope that made sense.
Also if you have clocked the t-case near flat then you do not nead to worry about driving in gear after 200 miles.
The real problem is the seal on the t-case will run hot and dry if not in gear. But if the case is flat then it is constantly bathed in oil so this is not a problem.
If the jeep is pretty stock, and it is a long tow. I would reccomnend pulling the rear drive shaft. Just mark its location prior to pulling it to make sure that it goes back in the same place. There can be issues with vibes if not put back in same place. It might not happen. But just mark with paint/chalk/marker to be sure.
Also be sure front hubs and setaring are unlocked.
