Frame up restoration of my 1981 CJ8
I swapped my 83 Iron Duke last year for that exact reason( highway driving).
Installed 258 engine ,but I still miss the duke all the time !!
it was just a great little engine with the 4:10 gears and T176
I'm looking for this little vent fitting for my AMC 20 rear end. Any ideas where to find one. I've tried Collins Brothers, Quadratec, Morris 4X4, Summit Racing etc. I can find the fitting, but only for the Dana 44 and other rear ends, not the AMC 20. Will the one for the Dana 44 fit the AMC 20 rear end?
The three following snips are from the '81-'86 parts manual:
Build is looking great. Keep at it and keep up the good work! Bringing back lots of memories for me, so many I'd like to do it again!
On my last 20 I just NPT tapped the hole and used a standard barb fitting...
Been cleaning more parts. Got the drive lines, rear leaf springs and motor mount brackets finished up. Now I can start painting again. I also got the shocks, engine gasket set and shock mount in the mail. Now I have all the parts I need to have a rolling chassis except the return fuel line.
Back to work on the Scrambler. I got a bunch of parts painted with Rust Encapsulator and then Extreme Chassis Black including the rear end, rear leaf spring hangers, AMC 20 brake backing plates and a few misc. parts. I also painted the leaf springs with rust converter and got the drive lines ready for paint..
Scrambler rear spring hanger.JPGPainted pitman arm.JPGIMG_3303.JPGIMG_3304.JPGIMG_3305.JPGIMG_3306.JPGIMG_3307.JPGIMG_3308.JPGIMG_3301.JPG
More parts painted. I did the drive lines, other brake backing plate, motor mount brackets and a couple other parts in Rust Encapsulator and Chassis Black.
I got the spring plates in place, put the Pitman arm partially on and fitted the tie rod from the steering knuckle to the pitman arm. I also put the other motor mount on and ran the return fuel line. I'm finally making some progress, it felt pretty good after spending so much time cleaning and painting parts.
