Front frame horn measurements
rsf
New member
Dallas
Previous owner of my Jeep welded some tube bumpers on the front and hacked up the frame rails in the process. I'm getting ready to weld in patches but am unsure of some of the feature locaitons.
Could anyone do me a favor and verify that these are accurate?
Thanks in advance
Here is a picture of a frame with “waho” plates welded on.
Bottom end to bumper hole center on bottom is close to 7/8”. Top is about 5/8”.
Both holes in the side of the plates are about 7/8” but don’t line up with the original holes.
Jason might be able to tell you what the dimensions are for his frame plates.
good catch on that bottom hole offset. Looking at the stock bumper I see that now.
the inner edge of one of the lower holes is all thats left and Ive been using that as a reference point. I would have made a bad assumption
I tried to mark your drawing up with my corresponding measurements.
These were done with a tape measure so everything is in fractions and by eye.:o
The measurements from the front of my frame to the hole centerlines are the only ones that appear different to yours.
The strange part is mine has two holes on the top of the frame, a 7/16" x 3/4" slot (5/8") back and a 7/16" hole 2-1/2" back (see photo on next post)
These don't correspond to your three lower hole measurements. (unless I'm misunderstanding the drawing and these are just your best guess and you need to add 1/8" to the frame length with the bumper mount still 5/8" back :shrug:)
Thanks everyone. I think I got enough info to get started patching
