Funny story...just don't tell my wife I said it was funny...
This was one of the things I regretted- having scrapped my bed rather than keeping the component parts, primarily the bed corners. My sawed-off Scrambler tub looks almost identical to your YJ tub there... doesn't stick out in those impale-o-rama points on the back though. :D
The main reason why bed corners would be hard to make work is because of the curve in the floor, and subsequent step-up, and the lean to the bulkhead that the stock rollbar fits into. If you were not going to use the stock rollbar, then it's feasible, but you'd have to do some funky metalwork to extend the tub floor to match the bottoms of the corners, and then use the tailgate or similar panel to match them from side-to-side... the tailgate wouldn't work, of course, because you'd have the bed or whatever back there.
I think you offered me the corners, but I didn't need them. How about this, you can bend some tubing to make a more rounded end to your cab, one high, one low...then skin it with sheetmetal. At least that way there wouldn't be those sharp corners to deal with. Lemme think about it some more, I might be able to whip you something up and you can have it tacked into place up there...... ;) I can use your pics and my bed as a reference.... My wheels are turning now...
(I realize we are now so off-topic as to never return to it, but in a vague attempt I will say that I would have laughed too- I'd have laughed my fool arse off, just at the irony of it all. :D )
I think the reason why I said tall corners wouldn't work is because I was married to the idea of making them work with the hardtop. If a person were to integrate the curve of the tall corners into that of the hardtop, and include some sort of top-of-body-esque ledge for the top to sit on between the two corners, it is feasible- just would take some creative space-filling between the floor and the insides of the corners. For that matter, if one weren't terribly concerned about customizing, he could cut the corners (so to speak) into the bulkhead, using the bulkhead to seal the cab from the outside, and the corners solely for asthetic reasons.
(crickets)
Okay, I'll shut up now.
No I won't, but I'll have another of too many beers and pretend real hard. :D
Honestly I'm not real concerned with having something that looked like real corners or anything rounded or whatever back there. What I was considering was that I would just cut those sharp corners down the angle of the bulkhead...and that would be the rear of my cab...then I would have the flatbed/small headache rack type thing creating the rear of the Scrambler.
I was thinking simple, cheap (relative to replacement tub) and short term.
Although, if you could draw out what you are thinking Bill I'd like to see it just to get an idea...I'm having a hard time visualizing it.
Heck, just get a piece bent with 90 degree corners, one solid piece all the way across- square up your existing tub sides, take out the bulkhead, and weld it in. Fill the gap at the floor with some sheet metal and seal the seams with sealer. Find an old Toyota (flat sided) bed and mount it to the back frame. Probably have to fab up some mounting towers. Add TJ rear flares, mount a roll bar to the frame, through the bed, and!!! Instant Brute! :D Sounds cool to me, and alot cheaper than an aluminum tub!
dadscj8 said:
Same here, although she has driven it on the trails. I think once i put an auto in it, she'll wheel it more. That may be good or bad.
I'm facing the same dilemna......I think I'll stay standard! :D ;)
-Will
