Gas Tank
lineforeman99
THE MADNESS MUST END
Montrose
co
I POSTED A QUESTION IN THE ENGINE FORUM AND HAVE NOT HAD A RESPONSE. I AM GOING TO BUY A 20 GALLON TANK FOR MY 84 SCRAMBLER TOMORROW, I HOPE. IT IS OFF AN 82 CJ5 LOREDO. IT HAD EVERYTHING TO INSTALL IT INCLUDING THE SKID PLATE. DOES ANYONE KNOW IF IT WILL BOLT ON TO MY SCRAMBLER WITH NO PROBLEM.
THANKS
BUTCH
Don't know
Butch i really don't know,but here is what i'd do measure it and measure you scrambler tank(mounting width) and see if they are the same,I'm sure it will work,now wheter it will be a bolt on i don't know,I do know that some of the filler necks are differant sizes,so that maybe a problem.Here is the info that i have on the tanks-1970-75 has a 2 1/4"dia. inlet and a 6 1/2" filler neck---1976-77 has a 2 1/4" dia. inlet and a 1 1/4" filler neck---1978-86 has a 1" dia. inlet-From what i've been able to find it shows the same tank for all CJs from 1978 to 1986 so by what i have as far as info it should bolt right in and the filler neck should be the same and the sending unit should hook right up--If it don't work let me know,I'm just going by what i can find in my books-JC:confused:
GAS TANK
THANKS FOR THE INFO. I HAVE HEARD THAT THIS WILL BE A EASY SWAP. ALTHOUGH I WAS NOT SURE ABOUT THE YEARS.
THANKS AGAIN
BUTCH
