Jeremy
Scrambler Fanatic
- Carlisle
- PA
As unemployment looms I am trying to get all my junk running. I had the 1981 cj8 going for a two weeks with a junk yard motor in it. On my way to work the other day the clutch fan that was on the donor gave up the ghost taking the radiator with it. 4WD hardware is back ordered till the 20th. But they were $120 cheaper than Autozone or advanced auto before my club discount. So that little project is on hold.
I need to have CJ running before the LJ goes into the shop for inspection.
So I turned my attention to the 1982 cj8, For the last two years it has been eating starter motor bendix gears at the rate of one every other month or so when I was driving it regularly. This is getting expensive so I parked for a while. Today I took a personal day at work and pulled then engine. I have had this engine in and out half a dozen times now, maybe I got a little sloppy, maybe it is fate catching up with me. But I had a minor whoops.
Understand that I lift motors with a come-a-long and a metal tripod. I took the winch off which was being contrary. The grill, the radiator and disconnected most of everything else under the hood took a couple of hours. I then crawled up on the front cross member to ratchet up the come-a-long a couple of pulls to take the slack off the motor mounts. The idea was to make sure everything is loose before I lift the motor free. It is during this little operation that the jeep lurched over the blocks (2) that I choked the tires with pushing them into the yard. The Emergency brake failed and with me standing on the frame rails the Jeep rolled forwards down hill across the yard for a good 10 feet. This had the result of knocking the engine free mostly, the oil pan skid plate caught on the cross member partially tearing it loose causing it to leak. It also damaged my clutch pressure plate. It also checked the tensile strength of my throttle cable and probably booger ed up some other stuff that I have not noticed yet. Luckily I am a pack rat and have a spare oil pan, and clutch housing so no real harm done just one heck of a scare. I hooked up the winch on the LJ and pulled the CJ8 up to were it belongs and got on with swapping the flywheel, clutch and now a oil pan to the project.
Tomorrow, the plan is to reinstall the motor, wrap the header with heat wrap as it is melting my drivers side motor mount to a gooing mess. I have a hydraulic clutch linkage kit that UP brought today so if the rain holds off I may get that done too. Then I should have both Cj8s running again with in the week.
let this be a lesson to all to be careful and triple redundancy when doing safety things like blocking up tires.
Wow! Glad you didn't get hurt on your little ride, Jeremy! Good luck getting the cj8s up and running.
