I removed lock pins, including retaining pin for cylinder.
Only retaining pin is shown in this picture:
Then I measured depth of lock cylinder. Cut new knob to length.
Then filed the point of the triangle so the shaft would fit snugly in key slot and press to bottom of lock cylinder.
I also marked the location of the retaining pin on the new knob shaft, and filed an indent so I could put the retaining pin back in cylinder around the new knob shaft. Like this:
Then I put some Permatex metal repair epoxy in the pin slots top and bottom to make sure things stay put. You can see I stopped short of the retaining pin.
So the retaining pin moves up and down on the tiny spring like it should, meaning you can install/remove the cylinder to the lock base as AMC intended.
And the whole assembly will turn freely, and work as before other than it no longer locks.
That works! I have the same lock cylinder on mine. Locked and unlocked fine but getting the door open was a problem. I finally cut two thin pieces of grip tape (think skateboard) and put a thin strip on either side of the knob. Gave just enough traction to pull the door open while turning the knob.
