Got my new 37's yesterday....
1BADCJ8
Silver Member
Silver City
NM
Mike (scrangler) dropped off my new 37X13.50 M/T Baja Claws yesterday afternoon on his way to Moab. Got them on my Jeep and drove around a little bit. They look really good and I know from my 35's they will perform in the rocks and such.
Only thing is I've got clearance out the gazoo and could have fit 38's or 39.5's easily. Only problem there would have been my axels... Plan to do axels next year any way, so.... there will probably be a set of like new 37in claws on the market next year.... lol.
I'll post some new picks soon as I get some....
PS - Mike (scrangler) was held up a little in his quest for Moab. Just east of Denver he shelled the tranny in his big Dodge Dually. But was back on the road yesterday afternoon. Every one has got to see the Bobed Scrambler he built for his girl friend. Coolest Jeep I've ever seen. Makes mine look like a stock toy.
I got 37s this past weekend as well...
I checked out your website, but didn't find a detailed description of your suspension. My question is, did you use 4" springs with your SOA to get 10" of lift?
I cut :eek: the tub and fenders on mine for extended TJ flares and still have the factory springs, shackles and narrowtrack axles on it (as the buildup hasn't progressed to this area yet). Here's a couple of pics of how much room I have, with the 37x13 Boggers bolted up:
My intention is to go SOA, but after I saw the clearance with the trimming, I thought maybe a RE 4.5" kit would be enough and a more stable ride on road.
Anyways, your comments on how much room you still have, even after adding 37s, prompted me to check on your suspension setup.
Dan, what axles are you running? have you gone with the high strength ones? I have yet to see Beth's Scrambler.
Sorry to hear about Mike's tranny but it looks like he is back on line. That truck is something else.
I think i've finally got me a trailer, i'm going to buy it Monday if all goes well. I guess my next investment is something to pull it with.
Looking forward to seeing you in July.
Hey guys,
Jimmy,
For the rear I used my 4 in superlift springs (minus the 1in add-a-leaf that was there) along with the 2.5in YJ shackels that were there already.
For the front I used Stock Rear YJ springs with a leaf added and an add-a-leaf. 1.5in still on the Shackel Reversal. This flexed like you wouldnt believe, BUT I bent the front of the driver top spring. Flexed it to much I recon...lol.
I do have a pair of brand new CJ rear Springs that are going in it with the extra leafs. The upper spring is a bit stiffer than that of the YJ Spring.
Any way its somewhere between 10 and 11.5 actually as I used YJ pearches also.
Phil,
Nope still have my Stockers but added 1.5in Spacers all around it so it stands nicely. Plan to drop it off with Mike next winter for a few months, the plan he and I have is to put axels in it and full cage in it then. I've desided to do a beefy 44 up frnt and a 60 in the rear with 5:13's. Either Detroits and twin stick, or detroit rear and ARB up front. The way to lock it is the only thing I have not desided on.
Cant wait to see you in July either buddy. It will be awesome to see every one again. I cant wait, period.
I went by Mikes in Topeka on my way home from Texas so I saw Beths Scrambler then, man-o-man its really sweet. I love the color of Blue they went with, if I ever paint mine its going that color. Mike says its from a 2004 Nissian 580???
Here are some picks taken yesterday afternoon at about 4pm. Yes that is snow flying, got about a foot of realy, realy wet snow. Sorry they are garage pics but it doesnt have a drag-link in it right now, its getting re-bent (into shape)...lol.
Thank you Dan!
I'll be using stock CJ rears and a small lift shackle - we'll see if that'll give me enough clearance to be happy.
You've got all kinds of room in there. Looking good!
How about 40s
Here is mine with a 1" body lift and 1" lift springs with a spring over-JC;)
I do have a add a leaf in the rear which will be coming out since the bob job...........I have also done a lot of sheet metal triming-JC;)
JC,
That looks awesome. I dont think I can get 40's under mine but do think that 38's would fit easy and could get 39.5's more than likely.
I NEED AXELS......lol. I think I'm going to an Auto trans mission as well.
Speaking of Body lifts I forgot about the 2in body lift on mine.
So Jimmy I guess if you count the body lift its around 12in total.
40s
Hey bro wherter a 40 would fit or no depends on how much up travel you have,remember i did "alot" of sheet metal cuting on the front fenders and the lower half of the rears,but it looks like 38s would clear with no trouble,now wheter your axles would hold up to that much tire and wheel would be questionable-JC;)
Actually...
Bro I've got as much cut out of my fenders front and back as you and looking at it 40's would fit if I put some bump stops in there... However you are right, these axels although they have been really tough, I dont believe they would hold up to even 38's. I believe these 37's will be the un-doing of them.
I think mine actually sits up as much as yours and I did out the spacers like you did, but just dont have those 60's.... dang-it.
