Got some rust to repiar on the Frame
Dmcgi97502
81 Scrambler rebuild
Naperville
IL
A previos owner covered up the rust on the rear of the frame with some angle iron. I cut off the angle iron to see what it looked like under and plan to cut out the rust and weld in some new metal. I was actually pleased because it looked better than I thought it would, I think its a good thing I'm an optimist. Here's some pics, anybody have some advice or tips on what to do or not to do when I repair it. Thanks,
Man, you are doing really nice work. Did you make a template for the holes and everything to look stock?
Truck
I was going to make a template and cut the holes but instead I used the good metal that was left from my rear crossmember that I need to replaced and lined it up to look more like original. I'm going to make a template for the other side when I do it though so it looks original.
Wow...
That looks good Duncan! I'm impressed.....I need to drop by and check it out...It's not like I'm never in the neighborhood, I only pass your exit 2 or 3 times a day....I'll see if I can get by soon and check it out...
Bill,
stop by anytime, just give me a call.
All,
Thanks for all the nice comments, I was pretty nervous attempting to fix the rust since I have zero experience welding or working with metal but I suprised myself. Now all I need is more free time to get more work done!
That is looking really good Duncan. Looks like new. Are we going to have that galvanized when we are done?:D I had mine done for $50. it may be more now since Zinc has climbed up in price but it should n't be much more.
