half door uppers
Raven
Glen Rose
tx
Can anyone tell me if the half door uppers for the YJ will fit good with the factory had top on the 8?
I noticed that on eBay the TJ uppers are curved on the corners and the YJ are not.
Thanks
SC
Most YJ uppers have a squared off corner and will not work with a half hard top. The TJ uppers are curved, but won't fit in the YJ half hard doors that fit a Scrambler. I have heard Bestop made some uppers that were correct, but I've never seen them. You can also graft some YJ and TJ upper parts together to make them come out right.
There are some aftermarket uppers that should work, but I don't remember the name of the manufacturer. 4WD Hardware should have them in their catalog. Kurt (Rubberhook) sold some on here last year, so you might try to get some info from him. By the way - they ain't cheap.
John,
I'm not quite sure what you mean by grat some YJ & TJ parts together. I'm a little slow some times can you spell it out for me? This is my first venture into the half door arena. I have already bid some uppers on eBay, hopefuly I will get out bid.
SC
Even if you get the newer YJ uppers with the curved corner they don't fit properly with a hard top.
Thanks for the information. I guess I'll have to go back to plan B...
SC
This is getting real interesting. I called 4whelldrive and they told me that best top made a fiberglass upper that will work with the factory hardtop on the 8.
I called bestop to confirm and they told me that they do not make anything that will work on the factory hadtop.....
SC
Raven said:
John,
SC
By grafting parts together, I mean you take parts from a set of both and do some fitting, welding and re-shaping to make a set that work right.
Thanks for spelling it out John.
Has anyone actually done this? If so how how did it turn out?
SC
Boy I hate to hear this, I had planned to run half doors with my hard top, now appears that may not work. anyone try the STC uppers?
trust, I just called STC & they do not make any uppers that will work with the stock hard top on an 8.
SC
They're used to be several brands of fiberglass uppers on the market (including Bestop) that were made for converting half-door YJ's to work with hard tops. They were pretty pricey, typically close to the price of a used set of full doors. I haven't seen any new ones for sale in quite a while...you can probably find some on Ebay.
http://cgi.ebay.com/ebaymotors/Jeep...002QQitemZ120015076118QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/Fibe...007QQitemZ170013421395QQrdZ1QQsspagenameZWDVW
Thnaks for the info Jeepskate. Any way to make sure I have found the right uppers before bidding? I found another pair on eBay.
I just got frustrated when 4whelldrive told me Best top made them, but when I called Best top told me that they did not make any that would fit a CJ8 top.
Thanks
SC
Any door that fits a CJ-7 top fits a CJ-8 top...just chalk that one up to whomever you spoke to at Bestop not being knowledgeable about 8's. The uppers will be advertised for '87-'95 YJ's.
Thats what I allways thougtht too. I called Collins brothers and they told me that the full steel doors were enter changeable, but that the fiberglass uppers would not fit period??
SC
Fiberglass uppers on CJ stock hardtop update
I just spoke with Adam at 4wheel drive. Adam told me that the fiberglass uppers for a YJ will defiantly fit on a CJ. This is after I had people from both Bestop & 4Wheel drive tell me they would not work.
The general argument that I had was if the full steel doors for a CJ are interchangeable with a YJ factory hard top & an after market hard top why wouldn’t the fiberglass uppers work as well. Adam stated that Bestop was just covering their ***. He told me that when he worked in sales he had sold several for this purpose and had friends that were using the same set up as well with no complaints.
Thanks again for your input Jeepskate.:D
SC
Thanks
SC
My yj uppers are not curved & actually square off like an overlander's style.
For me this is ideal since I use a bikini top & a windjammer
just my 2 cents :)
