Hard top issue
STEVE HONEYCUTT
Austin
I have an 82 Scrambler and have replaced the cowl gasket and windshield. Now I am unable to pull the windshield back to the original position and the hardtop mounting channel does not line up.
Any suggestions?
Is the gasket thickness different for the later years? Maybe you got one that was too thick? Just wondering. No real help
Most new cowl to windshield gaskets are made of a more dense rubber and won't compress like the original rubber does. I had that problem with an all original 82. I used razor blades to thin down the gasket and then a belt sander to smooth it a little more. If it won't compress, you have to make it thinner. Your other option is to raise the windshield up by loosening all windshiels hinge bolts. If you do it that way, you may find that the doors don't seal as well. If you can't find a good original gasket, cut the new one down. Maybe someone knows a brand of gasket that will compress.
