Has anyone done the math yet on Tire pressure?
tom keyes
1981 CJ-8
Louisville
co
Just curious if anyone has done the math yet for front and rear tire pressures? After rotating my new Interco Trxus 33x12.50x15 tires I noticed that the rears had worn more in the centers then the fronts. I am guess that is because the rear end is a lot lighter then the front and the tires were inflated to the 35psi max.
I read awhile back where someone had done a calculation of pressure for front and rear based on weight, but I can't find the page now?
In the 1981 owners manuel there is a section that is labeled "Tire Pressure Chart"
It has both CJ-5 and CJ-7 listed but not our CJ-8's.....
There are tables for:
Model, GVW rating, Tire size, Load Range, Normal Load (with sub categories of sustained driving over 65mph and under 65mph), Max load range with the same sub categories, and then wheel size.
Here is an example from the book for an L-78-15 tire for a CJ-7.
GVW:4150, tire size:L78-15, load range:C,
Normal Load:over65mph(front24psi/rear24psi), under65mph(front20psi/rear20psi)
Max Load:over65mph(front24psi/rear24psi)
I know my tires should have different psi ratings but anyone know how to calculate it out for our Scramblers? or just larger tires?
Thanks
TK
You could calculate it, but depending on the type of driving you do it might not be right for you.
I'd just use chalk, mark across the tire tread on all four and watch the wear pattern after driving a short distance. That's what I did when I autocrossed my Contour SVT to get the right pressure to keep from having excessive sidewall rollup while still maintaining a good contact patch :D
I wish I could drive mine often enough to worry about rotating tires and tread wear :(
I would go with the chalk thing. If you have acess to it a tire pyrometer is better as it can diagnose toe, caster, camber issues too, but it is a bit costly.
The chalk is pretty easy and cheep. Just go to the dollar store and get a set of kids sidewalk chalk. Then you just need to use a dry parking area.
Carl
I'd third the chalk method. I do as the others but then add 2 - 4 pounds in the front to adjust for edge wear on the corners.
