Heat in the Shop
eegs2k
State College
What do you guys use for heat in your garage?
I just moved and my new garage is not heated. It gets way to cold in the winter to be out there without any heat.
What is the best heater to get? I obviously want something that won't blow me up. Electric? Propane? What is the safest when working on my jeep?
can you use kerosene in your area? If you do invest in a CO2 detector also!!
Lookup monitor heaters. they are what people in Maine use (they know cold!)
It's like a kerosene heater that is vented outside & very efficient!!
My parents have one in our Maine camp & it's the only heat for the place we love it!!
I use a 30000 btu heater. Propane powered the Bottle is outside with the hose run thru the wall if the tank is inside it will frost up. I put a fan behind it, so it moves the air arround, essently forced air. I tried a kersone heater the tube type. Every time it lights it shoots a small amount of keroseen cloud out and STINKS. They are both noisy but they are cheap.
I currently use a propane upright heater, noiosy, cheap and effective. But it does tend to use up alot of oxygen...In my old shop in Utah I used a propane fired ceramic grid heater- it was a 24X40 footer with 12' celing, and one 24"X36" heater really worked good, and didn't seem to burn up too much O2. No noise either! The worst thing is using aerosol paints, carb, and brake cleaner in a closed room with an open flame heater. The fumes are toxic...and will give you quite a buzz/hangover...right before they kill you! So be careful!
I gotta friend who works at a trailer park, so i got a forced hot air oil burning unit out of a trailer home they were tearing down.My garage 24 x24 and it will chase you outta there.You can run it on oil or kero and burns alot less then you might think.Made a oil tank out of a 55 gallon drum.I do alot of work for my buddys and the price is often a case of beer and 5 gallons of kero.Of course they end up drinking most of the beer.LOL!!! If you think about going this way keep in mind alot of these units can be converted to lay on there sides by simply turning the gun a 1/4 turn.That way u can suspend it from the ceiling saving valuble floor space.
I use a gas furnace that a buddy gave me out of a store that went outta business...flip the thermostat to 60 and it's Hawaiian shirt and margarita time out there. My buddy used an electric unit out of an old trailer home and it worked really well too (he moved to Florida last year, not sure what he did with it when he moved).
An old automatic feed coal/pellet stocker. Nice slow burn, lot of iron to hold the heat. Uses about 2lbs of coal per day to keep the garage around 55, to keep it at room temperature with doors opening and such it might use 12 or 15 lbs. I forget the dimentions of the garage but it has 2 doors, 14 ft ceilings (built to accomodate a lift yet to be purchased) it will hold about 6 vehicles plus a small shop area (right now it contains 3 vehicles, a ford tractor, mower, and 4 wheeler with plenty of shop area. ceiling is insulated, some of the walls are (still under construction). Not a good option if you dont use your garage frequently as coal stoves are not exactly push button ignition but for me and my father who use the garage as a staging area and almost daily it works well. Probably costs about $50 per month to keep heated.
Sad thing is we need to add on soon!
thanks for the info. I need to start scouring the classifieds for something reasonable.
