- charlotte
- nc
Barney sent the replacement quickly. Unfortunately, it appeared to be very dimensionally similar to the first one. I installed it anyway last weekend. It still projects from the tub like the first one did. That said, it seems to fit a little better. I contacted Barney and sent him pics. He said he would talk to the mfr. and get back to me. I have spoken to him about this issue several times on the phone and he seems genuinely interested in trying to solve the problem- he has been a great vendor to work with. Attached are pics of the second one installed. The last pic, shows the second cowl seal compared to my original
After installing, I washed the jeep and this seal does keep water out. I am wondering if the projection is designed as a drip edge to keep water from wicking back under the tub. I still don't know if sealant should be used in the the grove where the windshield inserts. That stayed dry, so I am thinking I will not use sealant.
One other tip: When I got the the second cowl seal I unrolled it and let it relax on my workbench for a few days before installing. This allowed it to lay flat on it's own. The first one I uncoiled out of the packaging and installed right away. I suspect this may have something to do with the better results.
