Heavy Duty motor mounts for 4.0 for CJ-8
Alaskan Postal nutjob
FORUM MANAGER
Ok, cleaning up my empty engine bay today while talking about my complete lack of progress on the stroker swap with @yodabob I found that one of my motor mounts is cracked. While it's something I could clean up and weld, I'd just as soon go to something HD. There's the MORE and TDK frame side mounts and they both mention using a 4.2 block plate with a 4.0 engine, can anyone verify that this setup will bolt up to a 4.0 on the block side?
Any other good HD mount options out there that folks have used?
I dont have an opinion but I do have a set that have been floating around my shed. I think they are the "Bomb Proof" ones. You can have them if wanted. I'll take a picture today. Never used them and given my current situation, I have no need for them.
That would be awesome!!
I think these will work from what I'm seeing they simply bolt to the stock block-side mount that I have from the old 4.0.
The poly mounts with the centered studs are just poly replacements for the stock mounts and aren't part of this package, I'd only need the tall ones with the through-bolt. The "short" side of the MORE mounts replace those poly studded mounts, basically
