Help me decide: building my Postal
Alaskan Postal nutjob
FORUM MANAGER
Pop quiz hotshots: You need a new front suspension.
You have: $3000, FI, winch, lockers, bumpers, seats
GO!
1. Suspension (the rest aren't needed if the suspension isn't right)
2. Any left over money to the lockers
3. travel with a friend who has a winch and carry several snatch straps
4. Milk crate will work for a seat.
5. BUMPERS??? Don't need no stinkin bumpers :D
I guess my trouble is that I have the main bolt-on type things now... winch (to be installed), lockers, one pieces, bumpers (to be installed), FI (to be installed).
With those purchases I had it all laid out how I wanted to go about things. Now I know I want body armor, hence the group buy thread, but after that it gets a little fuzzy and I can't clearly make up my mind on what to do.
I can go simple with just replacing the lift springs, shocks, shackle hangers, and shackles... or should I upgrade to a SRS of some flavor.
I have enough to look for upgraded axle(s), but do I really need to go there when I'm only running 33's??? I found a local guy who can weld, so should I just have him weld the tubes on the 20 and keep at it with the lockers and one-pieces? (I now have 4.54 gears that came out of the -5 to install too :D)
This is why I'm in overload. I don't really want to space these things out too much because it ends up as more work when I don't put things together all at once and while I like working on it, doing redundant install/deinstalls isn't my idea of fun...
It's a good problem to have, but I need to get over this "Jeeper's block" and get a plan!
I've made this offer before.... if you need an extra pair of hands some weekend I'm only an hour away. Might cost you $10 for my gas or maybe a good cigar. :)
spend money, sure
I did a Spring shackle reversal since you have from suspention damage anyway. But plan on a new front drive shaft. Then FI and gears and lockers, I went with ARB but it up to you.
With those new gears and locker and one piece axles in the 20...weld the tubes (stitch weld around..not a continuous bead) and that thing will be plenty strong even if you go up to 35's. (eventually you might replace it, or truss it to keep the tubes from bending...shouldn't be a problem with 33's.)
As far as the front end. If you were gonna have more of a lift than 4" or a stock spring over...I might THINK about going with the SRS. Other wise, I'd look into upgrading the front axle and keeping my suspension the same (for the reasons I said at your house...when you go up to an obstacle you push your tires into it instead of your tires/axle flexing back away from the obstacle, and the travel of your axle now goes back...toward your fenderwell)
Do your long range plans include building it to handle 35" plus tires?.
Eric, you know this topic is kinda like, well, you know...everybody has one and they all stink! :D
