Help Me Design My Scrambler, please
Luke, Take a look at Acorbacho's full roll cage.
You have to be careful not to bang your head when you add top members (above the door) that are so far outboard as this...
Note how the front roll bar is attached to the frame under the floor (NOT THE DASH!).
BritScrambler said:
Attaching to the dash lacks proper strength.
This CAN be done, you just have to keep going from behind the dash to the floor to the frame and it has to be propery designed. This is not easy or simple, but it totally can be done and done well.
Simply bolting to the dash, however is NOT acceptable for all the reasons Brit mentions.
It'll probably be out of the budget of most people putting in a cage, but I thought it was worth mentioning.
Check your email Luke....Sent you inputs on your lift questions...hope it helps!
Just curious...any news?
BTW, I noticed that the photos above had broken links again. Hopefully not it is taken care of...
