Hood Awning Question...
TexasAg77
S.O.A. Charter Member
BENEFACTOR
Cleveland
TN
Knowing there are a lot of figure it out folks on this page, My question is, What is the best way to seal the joint between the back of the hood and the metal wall? Do you notch the back edge of the hood or some top flashing of some sort? Doing something like this at the entrance to my shop...
That would be a lot of notching. I imagine there is a filler piece sold by metal building companies for something like that. I know there is foam insulation shaped to fill gaps like that.
Agreed. A filler piece must be available. If I were to notch something, I would notch a filler piece/flashing as you note and not the hood itself
I have been thinking about this same question… about 4 minutes in this video is one idea for flashing… on existing building would require cutting the siding to insert flashing…
Video, go 4 minutes in…
Here is another video showing an awning install and how to seal gap near end. The door awning can be a hood…
