How cold does it have to get to freeze engine
Cold day:
Was around -45F ambient (summer time). Coldest was during a storm over the "winter" (24 hour darkness) when temps were below -100F with winds over 135mph (wind gauge broke).
I live in Canada... Not quite Mars...
Sent to Tapatalk via Eskimo powered dogsled.
For those with experience on engine block heaters and their use over the long term, do you have any idea on electric consumption. ? My experience with block heaters is new to me, one is on a 1990 dodge cummins 6BT and its factory. The other one is on a 2003 Chevy duramax. I only used the 6BT one a few times late fall but I have used the duramax one several times this winter during our below average temp spell. When i plug it in a can see my garage lights dim and its a modern 200 amp service. AK, are you running timers on yours which I hear some guys do to have it come on at like say 4 am but perhaps up there in those temps you have to have on all the time. And if a timer, I assume it would have to be something heavy duty?
Should be able to use same timer as for an electric water heater
HWH is on an 30 amp breaker and I think you can break 220 or 110 thru the timer !
Sent from my iPhone
I have a timer that I set to come on between 4am - 8am and it also will only come on if its below -10C.
It was $29 and is an actual "block heater timer".
I have never tracked power consumption.
This may not be too helpful, JJ, but I plugged my diesel in each night for the whole first month during my first winter of owning a diesel. I think my normal $60 electric bill doubled. I had no idea it would consume so much electricity. From then on, I just hook the power cord up to the truck at night and plug in the other end when I get up in the mornings. I can usually count on 3 hours of electricity for an easy start when below 10*F, but I haven't paid much attention to the time frame when the temps are severly cold.
I had a roommate for a while who had a diesel, and the power usage definitely went up (nearly doubled) in the winter with two vehicles plugged in (Duramax and Subaru). It goes up with just one (Subaru or ZJ), but not as noticeably. I picked up a timer two or three years ago, but it's just a generic-style (heavy duty though) from either Walmart or Fred Meyer that I programmed to turn on at roughly 3 a.m. and turn off at 11 a.m. It works and serves its purpose for us. Most construction in Alaska explicitly includes an exterior plug specifically for block-heaters. I usually don't bother to plug anything in unless it's 20 to 25 degrees F or colder.
In another roommate situation I was in, with two other guys who both had diesels (PowerStroke and Cummins), the circuit breaker for the exterior plug would trip when they were both plugged in to the exterior outlet. The one roommate just moved his extension cord to another outlet that was inside the garage and on a different circuit.
