How have you guys mounted your CB radios and antennas?
flashover604
Lancaster
Oh
Title pretty much says it all. I've got a cobra 25 I'd like to mount somehow. I really don't have any idea where or how...
My old Jeep had a Tuffy console that I put the stereo in. Then mounted my CB in the old radio spot. It never got stolen from where it was.
My CB is bolted to the bottom of my dash between the cig lighter and the aftermarket temp and fuel gauge pod. Basically under the vent knobs. And my antenna is screwed into the rear bumper. 4' firestick. Could be higher, but I park it in a garage at work daily.
Mines actually hidden behind the glove box door, as I use no glovebox. I use a $6 external speaker mounted to the bottom of the dash. Totally loud enough for highway use.
I use this for the 4' Firestick with a spring base attachment.
http://www.acmejeepparts.com/products/13008_07.htm
There a ton of different Model 25s out there (for example the "Classic" is a pretty old school model with a large case and the "LX" is a newer LCD display and a much smaller case), so I wont attempt suggest any specific mounting. Try to put it somewhere protected from thieves but still easy to reach, see and hear (look to see where the speaker is on you CB and mount it so it is not blocked). I keep my CB inside my Tuffy center console. For the antennae, I used the stock holes that were intended for the wood bed rails that came from the factory (I removed the rails a long time ago and repurposed the holes on the driver side to mount the antennae bracket).
I use a pretty long 6' flexible antennae so to keep it from hitting the garage door I drilled a hole in the roll bar and use it to secure the tip out of harms way until I want to use the CB
A couple of stainless button head bolts and washers hold the bracket to the tub
The mount itself is just a piece of bar stock bent into an "L" shape with mounting holes and a spring mount
I was wrong. It's a 29 LTD. I got it a couple years ago for Christmas. It's got the weather band and bluetooth for my cellphone. It's pretty slick. I need to de-funk the console in my jeep. It got mouse-ified...
Sounds like a nice unit. The other thing I was going to mention is the ground for antennae. Most use the body to ground the circuit so be sure there is no paint/rust/corrosion at the mount (that's part of the reason I use stainless fasteners). A fiberglass tub would require a dedicated ground wire to the mount. The guy at the radio shop said that poor ground is the number one cause of poor radio performance.
On all the trucks & CJs that I have owned over the years, I've always installed a cigarette lighter plug on the CB unit power cord, and ran the antennae cable to the driver's area, then either:
1. I mounted a bracket where I wanted the CB. I could then keep the CB unit itself separate, usually in a center console or under the seat, but out of sight. Since I didn't use/need the CB on a daily basis, I could keep it secure, then when I wanted to use it, like going on a trail ride or long trip, the CB would come out of hiding and be bolted in place. The two mounting screws on the CB unit were hand-turn knobs, you can hand-tighten the antennae, and the power cord on the CB was a cigarette lighter plug, so it literally took me a few seconds to install/uninstall, and I could use the same CB unit for multiple trucks, installing only an antannae/cord and bracket in each truck...or
2. Another option rather than installing the bracket with bolts to the truck is to attach velcro or magnets on the bracket and leave the bracket attached to the CB unit so that it "sticks" to the truck where I want. Then I pull CB unit and bracket already attached out of the center console, screw in the antennae cable, plug in the power, up and running. Again useful for 1 CB unit for multiple trucks, only needing an antennae permanently mounted on each vehicle.
Hope that makes sense, or at least gives you some ideas.
I mounted mine to the back side of my Tuffy console and put an external speaker on the bottom of the dash.
