Jeremy
Scrambler Fanatic
- Carlisle
- PA
You all may recall that I have been having problems with my transfercase (IH scout dana 300) poping into neutral while under under load in fourth gear. Incidently the detents are strong so it probably is NOT linkage related. Tonight I droped the transfercase down out of the jeep. For thoughs of you that also run a scout dana 300 there are 4 obvious bolts holding the transfercase to the transmission as you look at it from the rear output. As I discovered belatedly there is a 5th bolt hidding along side the front output (pretty sneaky). Otherwise it was simple to pull. remember to disconect the speedo and the breather hose too. Get some help to catch the the transfercase, it is not exactly light either. MY transfer case is now going down to HOAK'S 4WD in Wrightsvill PA to be rebuilt and have a terra low 4:1 gears set installed. (GAWD that was expensive) But hopfully worth it. In an case I hope that the $%%%$#@@! transfercase will stay in gear more that 1/2 mile so I can drive the jeep with out so much aggravation.
