I Hate Torx
bshewmaker
compulsive jeep buyer
Paragould
AR
Why did amc curse us with these enginerring anomalies. Who nees locktite? just bolt it with torx. they will never be able to get them out. OK OK actual question here. What has anybody had success with getting the bolt on the rear drivers side of the front mounting position of the roll bar out? all the mounting position looks like they have one thats going to be a bugger. I broke it loose but now as the head of the bolt rises the angle from the roll bar wont let the ratchet move up. Since I'm not using the torx bolts again I'm thinking about torching the heads off and using easy outs.
Roll Bar bolts
I had really good luck with a torch. I made sure that i just got the head of the bolt and then when i go the roll bar out i was able to get it with some spray stuff (KROIL the best) and a pair of vice-grips. GOOD LUCK
Ditto on the Kroil, great stuff. The front feet of the roll bar are attached to an angle bracket under the tub. Take out the top 4, even if you have to cut off the heads, then get the ones on the front side (behind the seats). The brackets will pull out and you can work on them on a bench in a vice. A lot easier. Also some very long socket extentions will sometimes get you there.
I used air. Much easier. Forget the hand tools, get an air impact gun and go! All of them came out except the two I torched off first. I wish I had started with that in the first place.
I just used a long extension. Once I broke mine loose, they didn't take much to run them out so leaning the bit wasn't detrimental. The impact did snap two bits in the process, but they were Craftsman so wasn't worried.
I had such good luck taking out my torx that I put them back in. Figured everyone hated them so much, I'd leave something in place to make the knowledgable folks that actually work on their rigs cringe if they did a detail inspection of my rig. :D
I went to the local Lowes and bought a whole bunch of different sized nuts to weld on to the torex blots so I could use a standard socket to get mine out. After I welded the nuts on I soaked the bolts with PB blaster, that stuff is incredible. Anyways, using a ratchet with a long extension I was able to brake all of the blots loose on the roll ball and use an air ratchet to finish the job. I did have one snap off at the head. Looking back welding the nuts probably helped out just as much as anything since the heat from the welds probably loosened them up too.
Just my 2 cents worth SC
I used the impact on the 3 that are easy to get to, with a little heat they came out easily. I guess I'm just gonna torch the head off the last one.
thanks guys for your input
