I thought this was called a torsion bar?
ManyFacesofSchwinn
Active member
Silver Member
Rathdrum
ID
I can't seem to find any reference to this bar and I can't remember where it bolts on. It's been almost twelve years since I took it off. What is it called if not a torsion bar? Please Help! Thank you. Barry
Believe it is the motor mount frame support. Goes under the motor frame rail to frame rail via motor mounts...seem to remember that is where I took mine off from. It will go back on this winter.
Thanks guys. I'm a long ways from there but was painting parts and started cleaning it last night and didn't have a clue.
Its a Tie Bar, looks like its supposed to go thru the lower rear mount corners, as i recall it really only fits one way.
Mine goes to the REAR engine mount bolt on the drivers side, but to the FRONT engine mount bolt on the passenger side. I'm not sure if this is correct thought. I looks like if it went to BOTH rear bolts it might hit the oil pan(?) Anyone know?
In the top left of the diagram it says "Front", so as I see it, that's the rear bolt on the drivers side. But harder to see on the passenger side!
This is the position and location of mine where they were located from the factory for 36 years until I removed last spring. Hopefully you can tell in the pictures.
My bad..just noticed arrow. Bottom rear both is now my New 2 cents. Good thing I haven't installed mine yet.
