- Manassas
- VA
Event was awesome. Great to see folks we only get to see once a year park was great all was well. Jeep looked like it was going to work great and that LS sounded awesome turning those 42in tires. First day went pretty well in the beginning. Then after lunch while trying to climb a ledge I pulled the front driveshaft apart and messed up the slip yoke splines. @PAPPYWAHO had a spare that went on and we continued on being very careful of the hop in the front shaft.
Second day also started out well. Found some technical rocks that were very fun and the jeep was doing very well. Still had a little more hop in the front and rear than I was hoping for but I was starting to figure it out I thought. Then towards the end of day two trying to climb another ledge I had to give it a little bump and bang the front driveshaft not only came apart but twisted into a pretzel. @Jeeperdd and @timothy were able to secure the driveshaft and remove the slip yoke so we could winch me up and out of the trail. This went smooth as it could however my winch decided it didn't want to spool out under power anymore. This is also went we thought I might have bent a spring. Turns out what looked like a bent spring was a spun axle tube on my 14 bolt. Once off the ledges we were able to drive back to camp under our own power but decided it was best to put the rig on the trailer and fix it right when we got back to VA. Third day we spent at Bass Pro Shop in Springfield: i would recommend this if you ever get the chance the NRA museum was very cool. Now for the part you all like the pictures of the carnage.
