IAFFCJ 81 Scrambler
Only have one day this week that I'm not at work but I got some work done on the frame.
Finished the drivers side and plated over the seams of my patch just to be sure.
Started on the other side. It wasn't as bad and only needs the inside section repaired. Went a lot faster but still a pain.
Also plated to damages sections in the front no rust holes in these just dented so I plated over them to add some strength.
Thanks guys. My welding has definatly gotten better doing this project.
Picked up my rear axle from Chaos Fab Shop. They re-geared to 5.13, installed ARB, and shaved the housing. Came out really nice and I got some paint on it today going to try and get the brakes installed and get it all put together this weekend.
Continue to work on the frame as well. Got the frame plates on the rear welded on the bottom side. Once i get the fronts figured out ill flip the frame over and finish up the welds.
Ran into a slight issue with the outboard kit today. The locating tab on the shackle hangers don't seem to be quite right as I was mocking everything up my measurements came out to 43 1/2" and the installation sheet calls for between 44" and 44 1/4". Called Blue Torch and talked to the tech support guy who has given me a way to remedy the situation. They asked that I try and determine the angle of the bend at the rear of the piece to see if there is an issue with the bends. Will figure it out tomorrow and hope to get them welded on.
I did get some paint on the rocker guards this morning as well.
About 95% done with the frame. Need to free up the bolts for the cross-member or drill them out have them soaking in some homemade penetrating oil right now will see of they come out tomorrow. Still need to mount the rear shackle hangers and clean up some of the holes to mount the fuel tank but as long as the bushings i just ordered are correct I hope to be able to set it on some axles soon. I sure hope all this welding works out and everything lines up as I planned I think I may have worn out a tape measure with all the checking and rechecking but until the axles are under it I am still worried.
Got the brakes installed on the 14 bolt while I was waiting for the wife to get home. All that is left is some axle shafts and put some tires on it and I will be able to roll it around. Then once I get springs on the frame it will be time to set some spring peaches and pinion angles. I also have a traction bar set up that needs to be assembled and figured out but that will have to wait till the axle is actually located under the frame and I can work out what I am going to do for a cross member and belly pan.
Nice fab work. Then your going to put a body on it and cover up all that nice stuff.
Well i hope to put a body on it we will see if it all still fits together with all the welding i had to do on both. :)
Well tried to put the springs on today and ran into a little problem. I ordered 2 sets of spring bushing sets. Well with both sets i was able to do 2 springs. Need to order some more of the larger bushing these springs use to finish this up. Hardware to mount the axles should be here tomorrow so rollong chassis soon i hope.
Got the axles under the frame the other day. Definitely have some adjustments needed for the front drive line angles are way off and the u bolts i ordered dont have enough threads to get tight. But it rolls and is home so i can tinker more often.
