IAFFCJ 81 Scrambler
Parts pile. Picked up some paint so i can try and start getting some parts painted up as i get them ready to mount. Now i just need the temps to get above colder than the dark side of the moon.
Good luck with that for the next week.
There's heat in my garage :smokin:
Well that would be nice. It will defiantly be a priority when i get to build my second garage. Ive been using a shop heater and it takes the chill off so my hands don't hurt quite so bad but i don't think it will cut it for painting.
And speaking of the cold in case anyone was wondering dead-blow hammers will shatter if they are cold enough.
Well i thought i had collected all the parts i needed to get the Dana 44 for the front of the scrabbler all put together minus locker. So I braved the 10 degree weather and headed to the shop. Was pretty productive until my hands couldn't take it anymore. Got the old steering knuckles off, new ball joints installed in the new Knuckles, got them mounted, and replaced the u joints in the axle shafts. That is where the day went down hill. Shot side shaft went great and looks good but the long side shaft i was able to push the u joint caps on by hand. Well somethings not right there. Turns out the ears are stretched. Just a little on the inner but very bad on the outer. So i guess its time to look for new axles shafts. If anyone has a set for the long side of a Chevy 44 with 19 spline outer and i am pretty sure 30 spline inner they would be willing to part with it would be greatly appreciated. Still full width also has not been cut down.
Some pics for those who like um.
Picked up the frame from the sandblasting shop. There is something about freshly blasted steel. Looks pretty good. One small rust through turned out to be two large rust holes but thats what welding wire is for. Gotta get the wifes car to pass inspection then time to get started on the frame.
Also ran into a little problem with the axle builds. The gears i had in the 14 bolt wouldn't work so being i needed new gears decided to go 5.13. Now just trying to figure out if im going to put a bunch of money into the 44 to get it to match or bail on it and use that money to build the 60 i really want. Have a few places working up pricing on a 60 we will have to see what they can come up with.
Well the Dana 44 has been abandoned for this build. Found a 60 that I should have in my possession next week. Just got a call and it has been pulled from the truck it is currently in will need to get some lock outs and new calipers but other than that it should be ready to go already geared 5.13 an locked. Can't wait to pick this thing up.
Found some time to work on the tub today. One body mount down i think 3 to go. repair to some supports and a big patch in the quarter panel. Ran out of time to close up the welds but should be able to get to it in the morning. Defiantly faster after all the patches on that 7 tub.
What plans do you have for the frame, are you going to plate it or cut it out and weld in new metal. Watch below the shock mount and in front of the parking brake cable bracket. I've seen on two of mine that you get that rot all the way to the front of the skid plate. Are you going to shoot something in the frame rails to seal the rust inside? Nice work on the rear side of the tub. I've never seen the steel wedges that you've got to hold the patch piece in place. What's the back look like to wedge it in place?
Jammer. The plan is to cut out the rot and replace with new steel. I also have frame stiffining plates from Jason for the front and back but they are on the outside of the frame. One everything is replaced i will make the decision if i am going to plate the inside as well.
Oh and yes i am going to coat the inside of the frame. I used eastwoods internal frame coating on my 7 tub and really likes it. Also here is a picture of the sheet metal clamps i am using. They are just cheep n ones from harbor freight but seem to be doing the job.
Had a few hours before i had to head to work got some wheel well repairs started.
Old miller 200 .30 wire set at low voltage mark 2 or 3 depending wire speed around 30. And lots of practice on the other tub this one is going much better.
Those are nice clamps beats tacking a backing strip then pulling it off. Nice work.
60 is home. Now just have to figure out how to get it out of the truck. :p
Just wanted to say thanks to JeeperDD for riding along on the 60 pickup adventure. It was quite a day, trip south to get this axle, over to Richmond to see John N and grab some lunch and almost 450 miles i have a new axle for the scrambler. Was lucky enough to find an axle that was already geared to 5.13, locked with a Detroit and 35 spine outers. I will still need to get some locking hubs as it did not come with any but I managed to get it cleaned up and primed for some paint today. I'm so exited to get tires on this and get it under a frame i can barely stand it.
Plus we had good BBQ. How'd you get it out of the truck?
Good to see you guys.
Heck yeah John that was the best BBQ i think ive ever had. Thanks for intoroduci g me to that place. Got it off the truck with my engine hoist and some creative rope work.
Got to try the baby back ribs next time.
