Ignition control module keeps going bad need help
gary81cj8
pace
fl
Long story short. FRame off restoration on my 83 with 258 straight 6. Jeeps been down for year and half. Nothing on the engine was unplugged. Just removed from the firewall and fenders. Every thing put back together tried to crank. It will turn over but not fire. The ICM had smoked a hole in the gel. Replaced did the same thing. Just not a big hole second time. HAd a friend help me today. Noticed the ground on the coil was melted. Also the grond on the ICM is now a hot wire. WE removed the wires out of the harness. Some were melted together. Pulled them apart checked the wire all the way into the brain and down to the dist. I still cant find were the ground is picking up a hot wire. What am I missing? Thanks in advance
Did you not burn any fuses when the ICM burned up?
Install a DUI coil and never look back! I love mine, it was like night and day.
None of the fuses were blown. Gueon are saying the coil may be the problem. Can a coil cause the icm to melt down?
