Info on Jeep Commando
fitchjr
Huntsville
I found two jeep commandos for $500, on craigslist. I have never dealt with the commando so if any of you can give me some info, that would be great. I thought they came with d44 but I cant figure it out for sure with searching. The axles are the main thing I would want.
Also I would probably just part them out so if your interested in anything, let me know.
http://houston.craigslist.org/pts/625787669.html
'72-'73 Commandos have a flanged rear D44 that will bolt into a CJ. The one on the right looks like it would have this axle. The one on the left would not.
Craig
The one on the left probably has a D44 rear with 2 piece axles, or a D30 rear- neither are any good. the front on the left is a closed knuckle D27, again, pretty worthless. For an engine, the one on the left probably has a 225, a BOC Th400 and a D20 case. The adapter is worth a bit if it's not broken.
The one on the right has an open knuckle narrow track D30 with drum brakes, and a flanged D44 rear. Both decent axles. They both bolt right in to a Scrambler. The gears are probably 3.73, the rears usually had trac-loc limited slip. Engine wise, a 258 or a 304, BOC Th400, and a D20 case. 104" wheelbase, I've seen Scrambler bodies put on Commando frames.
Parting them out usually brings pretty good $ if the trim pieces are in good shape. Hinges, latches, seat pedestals, clusters, all bring good $ on EBay if they are in good shape.
just a thought
Just a heads up, my Sramando, is a 4wd hardware fiberglass body on a '73 commando frame. If I remember correctly, there is .4" difference in the wheelbase, and it is completely unnoticeable, even to a Scram fanatic. It has a 304, th400, dana 20, and flanged axle 44 basically from the factory. All the body mounts, rollbar mounts, and crossmembers are where they should be. The major difference, is the length of the rear frame horns, the outboarded rear springs, and the overall rear spring length. It really results in a great ride with the long springs, that have to worry about quite as much as if it were real. Downsides are Narrow Track Axeles, and hell Creek, and Alcan are currently the only mfgrs making lift kits, and they are $$$$$$$$$$$$$. Heres a pic, Im just throwing it out there as a possibility. My family cage is now gone, and I have a Scram factory roll bar, so it works pretty well. Let me know if you want any specific pics, I put some more on another post, pics and post below.
https://www.cj-8.com/forum/attachment.php?attachmentid=10331&d=1204159660
https://www.cj-8.com/forum/showthread.php?t=19457
