Install snaps?
0maha
omaha
ne
Ok, I'm low buck. That's just the way it has to be. I also like things to look nice. So here's my dilema. I can get a nutmeg soft top for about <$300, but it's the snaps type and I don't have snaps on my jeep body OR I can get a white fast trac 'like new' soft top for about $350...I prefer the nutmeg.
How hard is is, and is it recommended, to install snaps onto the jeep body.
I'm not very experienced with body stuff, but I'm handy with the wrenches so if putting snaps on a body that doesn't have them is a bad idea let me know.
Suggestion
Go to a Marine dealer and you can get snap tracks,it's a rail with where you can slide the snaps around to where you want them,the rail mounts to the body,or you can buy the fast trac rail and take the top to a ulpostery shop and have them sew the male part of the fast trac system to your top-JC
Just a thought....
Find you an upholstery shop and see if they could sew some velcro strips along the edge of your top....In between the buttons...
Then you could stick the other side of the velcro on the Jeep. You would have the look of the snaps, but the benefit of velcro enclosures, and no nasty holes where the male snaps drill into the Jeep.....
Just my .02.....
I can tell you....
....that the upholstery shop route is very expensive (see custome top). James' suggestion to get a snap rail is probably going to be your best and least expensive option.
Not only cost effective but wont look bad either then when you get a fast trac system simply remove the snap rail and put on the fast trac. :cool:
Unless you have a flaming deal on a new original top, and dont forget hardware if you dont have it just buy the STC. I just got mine, not the perfect arrangement, could be better but it works and looks good.
Will be installing it when I get my last bit of touch-up done after I install just a few more parts ;)
I just installed my fast trac today. I have a friend with a CJ7. I am not sure what kind of top he has but it has snas on it. The snaps are a pain. I helped him put the top up last weekend. I would go with the fastrac. Hard deciesion, that nutmeg is a good color.
From the sounds of it I'm going to be better off dropping the cash to get what I want. It puts me back a bit 'project wise' but that's ok, I'm still shaky on what the project plan is...there's a lot more rust here than I think I can restore...looks like we might have a really nice offroader instead of an oem restore. you won't catch me complaining.
