It LIVES!!! The FABLED 8 Build Thread
I'm continuing to prep the stroker for install this winter. I degreased everything, put new plug wires on, and got a YJ water pump installed. I have several other parts stockpiled for the swap, new motor mounts, fuel pumps, etc. I'm waiting on cleaning up any more of the wiring until I have the engine between the frame rails.
New water pump installed
Hey... who stole my grille?
Today, I got to work on pulling the 258. I drained and pulled the radiator and the grille. Pulled back the headlight and winch wiring and some other odds and ends.
I figure I've got a couple more days or 1 more long day to get it pulled.
Next up is draining the engine oil, t case and transmission. Then removing driveshafts to remove the dana 300. I'll move onto underhood wiring and hoses after that.
I made a little more progress today.
I drained the transmission, took off the crossmember and took out both drive shafts.
With the jack stand in place, I had to get creative with the funnel to get the fluid into the drain pan.
The cross member was about 10lbs heavier thanks to all the mud built up.
I figure next is drain the t case, pull the shifters and drop the t case. Then start pulling back electrical from the engine.
More progress.
I drained the Dana 300 and loosened all the bolts securing it to the T-176. I have my 300 clocked and can see I've torqued it up enough to hit the underside of the body.
Then I removed the underhood clutch pedal linkage, the floor plate/ shifter boot and transmission shifter.
It's out!
I finished up pulling the engine with a friend today. We didn't take too many pictures as we were moving pretty quickly with some other obligations today.
We dropped the t case out, pulled the rest of the wiring from the howell efi kit out of the cab and split the under hood wiring harness. Next we pulled the power steering, the vacuum lines, fuel lines and the exhaust.
It came out pretty easily, only getting hung up on a few things, the starter on the motor mount, the shift tower on the body and the exhaust downpipe on the exhaust stud. All were addressed in short order and we got it out.
I'm going to clean up a few things with the engine out, run new brake lines, perhaps put in a tilt column that's on the shelf and a few hundred other small items. I'm tentatively planning to come to the Nationals next year, so I have to keep that in mind as I consider other projects while I have everything apart.
I tinkered a bit more and removed the Dana 300 clocking ring to prepare to install the Novak adapter to the AW4.
I still have some cleanup to do before the final mounting.
Yesterday, I scrubbed down the inside of the frame rails and put in the new Inline Tube brake line kit that I bought 5 years ago on Black Friday!
All the lower lines heading to the front and rear axles fit perfectly. The rear axle line doesn't fit since I've swapped to a Scout 44 rear and the lines from the master cylinder don't fit either since I did a YJ power brake booster upgrade years ago.
I had a little spot of paint that was peeling on the front of the frame and I started scraping...
Some more progress was made towards getting the stroker installed. I cleaned up some of the accessory pulleys.
I also eliminated the XJ oil filter adapter as it is a known source of leaks and isn't necessary for the CJ install.
I continued to touch up the engine accessory brackets, reinstalled the frame side motor mounts and drilled out the CJ engine block plate. I'm also checking out a kit to relocate the alternator up to the factory AC location since I don't have AC in my 8.
Frame motor mounts
Alternator
Motor mount
Cleaned up some missing/incorrect bolts on the starter and CPS.
Today, I got the alternator relocated to the top of the AC bracket. I think it will work out well and clean up the front of the engine too.
I have some misalignment of the power steering bracket that I'll have to figure out. It mounts fine to the water pump, but doesn't line up with the intake manifold mounting hole.
I also got the motor mounts installed.
Oh yeah, and I got the Stroker mounted into the Scrambler!
I still need to work on wiring, fuel and the transmission crossmember, but the engine is IN!
Another fortunate discovery tonight. The power steering bracket wasn't lining up with the 3rd hole in the intake manifold. I loosened the newly installed water pump and lo and behold, the holes just barely line up. I'll have to reseal it, but at least I know it fits now.
I spent my black Friday morning in the garage modifying the transmission crossmember. It's in and aligned ok, but I'm not happy with the front edge of the crossmember resting very slightly on the AW4 transmission pan. I'll have to either add some spacers under the mount or modify the front of the crossmember.
My plan is to mount the Dana 300 and mockup the driveshaft to see what other modifications might be necessary and to look at the driveline angles.
Today I got the old seal removed from the Dana 300 and the new one pressed in. On the suggestion of the local parts guy, I used a drywall screw to remove the old seal without disassembling the front of the case.
The new Novak seal went in after a little persuasion.
I also got the power steering pulley installed with the loaner puller/installer from the local parts store.
I hope to get the Dana 300 mounted up tomorrow if I can get some help from a buddy.
I'll also need to get the winter tires installed on my wife's Durango in the morning. The joys of winter in Minnesota!
View attachment 123985View attachment 123986
Good idea using the drywall screw. I've got my dad's old Craftsman hammer like yours with the metal sleeve next to the hammer head. Yours is the first one I've seen like it.
