- Silver City
- NM
Finishing this 1.5 handed was a chore to say the least but it looks awesome. Also if not for some pals it would still just be sitting there, waiting to be finished.
Every article I've read on doing this retro fit says that the rears flares are real easy and very trivial compared with the fronts, well make no mistake its true.
I did do a few things different than I read or was instructed. One main thing is that I didn't want to cut out my fender wells, I wanted those to stay intact as much as possible and as it turned out I saved and used 99% of them. This allowed me to keep all the mounting surface for my radiator over flow and wash fluid bottle. They do mount different as the well is no longer flat, its more rounded now. So pulling prodding and beating with the 'ole hammer saw to that. Still using all this I still gained 3 in of clearance on the top and 4.5in of clearance in the back of the front wheel wells.
The flares actually puckered a bit at the top center where there is basically no mounting surface because as stock it has a lip to help it in but that has to be cut off. So what I did was along the top I used a 1in by 1in piece of angle and ran 3 bolts through it, through the flare and into the fender. and that snugged it up nicely. Then, while I was at it, I ran flat bar along the rear mounting bolts and snugged that down and it looks real clean. To rejoin the wheel well to the out side pard of the fender I used 3/4 X 3/4 angle steel and 4 bolts with ny-locks along the back part of the wells, no welding needed.
In the front of the front I used a Wagner paint stripping heat gun and molded the plastic a bit to better fit the CJ. You have to be real careful with this as it turns very, very soft and will tear easily. As most of you know, the fronts usually use 7 little screws and little plastic things inside the fender wells. I used 1/4X20X3/4 in bolts with ny-locks (nuts) instead of the original hard ware. Also I used 13 per side, these babies are NOT coming off real easy. This in my estimation truly helped synch these flares down to the CJ.
Although all of this helped it have a more natural look it still had a very smallish gap in it that I didn't care for. I looked for black calking but as I found out (pretty much already knew it but one can hope) there is no black caulking. SO; I used Black Magic Permatex. Yep Permitex gasket material. It was a serious mess getting it off the fenders and flares but really, really finished off the job how I had hoped it would.
The last thing to do was to cut the original rocker covers to size and actually get them right. Well I really took my time on the driver side and they came out fantastic. I mean I got them as close to perfect as you can with a hack saw and eyeballing it and it does look good. However on the passenger side I'm thinking "hey I'll just flip this one over on it and draw my lines." Well the angles were perfect but the passenger side was 1/2in longer so I cut the rocker cover that much short. It doesn't look real bad but really pissed me off that I didn't take my time, but after literally an 8.5 hour day working on the Jeep I was ready to be done.
All in all I'm very pleased with the out come and think it was worth the time and effort. Worth cutting my hand that bad???? Maybe not but that aside it is worth the effort.
This is what it looks like. I'll try to get a strait from the side shot to compare it to my projected look, I think its close. Also earlier in the week I got my shortened nerf bars back and welded those on as well, they also look good.
