What was the problem? Are they different tail lights. Pics look like different tail lights. Glad they work, another step toward having her on the road.
Well, a culmination of issues that led to them finally working.
Basic problem solving 101... have enough time, remember all the things that came before, what the differences are... get a blender, put them in, mix them up.... kick yourself in the head a few times and then it is solved.
1) Different steering column... went to a tilt, someone rebuilt it before me. The turn signal switch end would not "snap into" the one on the painless kit. I got a new one.
2) Prior to this, I thought it was the brake switch... went out to my 4-5 extra assemblies and believe it or not, not a single one had a brake light switch... checked old harnesses, same thing... ordered a new one... this was not the issue.
3) The wires that go to the brake light switch had been hacked... in fact, the whole harness was... remember this was a RHD setup, so a LHD painless kit didn't have the lengths in some areas... the solder joint on one side of the connection was great, the other side, well it wasn't as good. I cut it out and put a jumper wire in there and it was better, but still showing taillights in the blinkers.
4) Grounding is an issue with all rear lights... it especially is bad when someone has swapped colors. The pink wire coming out of hte brake switch was 12v, however, when measured, it was like .5v... so searching and cutting open the whole PO added lengthening cable to get tot he rear I found the pink/black to be switched.
Nothing really bothers me day to day... only stupid people and really stupid solutions. Using a black wire for 12v HOT is just something I can't comprehend ever doing.
It was at this moment that I had a flashback to when I got the Jeep.
The rear wiring was a mess, so I used a trailer plug to get the necessary wires from the left hand brake light assembly to the right side. I was able to wrap it in tape and just push it through the loom on the old tub.
I never looked at the actual wiring, I just measured voltage and adapted the new harness to it... so I never noticed what was ground and what was hot, just when the blinkers are on... this wire(s) same with brakes, and reverse.
So, you rip it all out and put it in a new tub, well, thing start not to work and you know it worked before, it can't be too many things, you just have to remember what has changed... and some things had.
I then stumbled upon one last piece of the puzzle and that was a wire tucked into the look that had been cut... PINK!
So, that wire was still connected to HOT, but the end was cut and stripped, so the copper was inside the loom mostly, but was poking out and rubbing near the tranny tunnel was I don't have it tucked up and away... somewhat dangerous and very difficult to find your grounding situation.
I have seen a couple of those type of things with this wiring... it "worked" before, but I think it was all just in the perfect position and nothing was touching what it wasn't supposed to be.
I will fix it all up, just annoying to waste this much time (and money) chasing gremlines that are a result of pure laziness and using "what you got" to get it done.
Take the time, go out and buy some other colored wire than black, it will trigger someone quick that something isn't right!
I just had 3 cups of coffee... can you tell?
