Long boys,
Yep, I'm still alive. This is the first time I've checked in for about 6 weeks. This workoholic crap is not what it's cracked up to be. Things just lightened up a bit.
My website got dumped by mac.com and it should be up under another ID soon.
Went on another self-flaggilating jeep trip just after New Years to Johnson Valley. Did many of the named trails with most of the Beater Boys. Frank's newly built Jeep, and I mean 'built', lost all alternator use early on, so he retired and rode along with Mark or I, each in our matching '82 CJ8's. It's really wierd to see two CJ8's come along, same color, same year, same most everything. He's got a HP Ford 9" rr axle and two transfer cases. Frank's newest creation is a 100" WB, '43 Willys with GM 4.3L, D44/D60, 5.38's, Locked, NV4500, 4:1 D300, Wagoneer SOA, etc, with his homebuilt frame and winch on both ends built into the frame members.
Things were going swimmingly on "Outer Limits" until my left frnt. spring pulled right off the frame (on the stationary end). Both 1/2" rivets and the welds pulled right off the frame. It took a while with jacks, come-along, winch fed down under, and prybars to get the axle re-located. We welded the bracket back to the frame sans rivets. Except for that slowdown, we had a great time. Nothing else broke and I was pleased with the new front end up grades to my D44: [Warn ChroMoly 4340 axles, CTM U-joionts, Parts Mike steering over arms and outers, and Hayes ChroMoly/3/4" Heim Joint tie rod and drag link, chevy brakes]
Since that trip, I've got the Go-2-Guy clocking ring on the t-case and Frank fashioned a new skid plate, without the annoying "300 hangdown" to hinder one's progress. However, I need to get the front driveshaft lengthened, it was a little short before, and now with more distance between the front yokes to span, it needs more length. Also, the rear driveshaft is now a bit long with only 1" on compression left at street height. Do you think that's enough compression?
Contrary to news reports, we're not moving. As much as I dislike the politics in CA (that guy's an idiot), we're here. I have 3 days off between now and June 1st, a pretty grim prospect. On June first Jeanie and I will take the Cummins/Lance (no Jeep) to Alaska. I have 5 weeks to do this and we'll be taking all the poor or doubtful routes, like the Cassiar Highway; 500 miles of on and off gravel. I need to get a rear locker for the Dodge Cummins. Any Ideas? It's an open Dana 80.
regards, as always, jefe
