chavezychavez
- Chickasha
- ok
Guy's
That was a load of fun not! I wont know until tommorrow if the thing leaks after all that trouble I think they where the original gaskets
I will be changing out the valve cover gasket as well tommorrow. I really hate the fact that it is a plastic valve cover anybody know what years with metal valve covers will inter-change on the AMC 150 4 cylinder motor? Anyway's Pepe is running great now that I replaced the ING module that was bad.
I needed to do this work and glad it is almost over the little 4 banger does not burn or use any oil but was leaking about a 1/2 quart every 200 miles so decided to correct tha problem once and for all
Take care
Matt
I will be changing out the valve cover gasket as well tommorrow. I really hate the fact that it is a plastic valve cover anybody know what years with metal valve covers will inter-change on the AMC 150 4 cylinder motor? Anyway's Pepe is running great now that I replaced the ING module that was bad.I needed to do this work and glad it is almost over the little 4 banger does not burn or use any oil but was leaking about a 1/2 quart every 200 miles so decided to correct tha problem once and for all
Take care
Matt
