Largest tire on D44
kohldad
Goose Creek
SC
For the weight of a Scrambler, what is the largest tire you would feel comfortable running on a set of D44 axles without much worry about breaking? I am afraid to roll but don't mind using the skinny pedal in low range. Will never (shouldn't use that word I know) upgrade the engine or tranny.
35's with a locker
I have seen people break the 44 with 37's on a TJ. You can upgrade the axles to chomoly (sp?) and run 37. W/O a locker and with light wheeling you can up to 40 I bet. I have a buddy with 38.5 swampers. Eat's shafts like candy, going to Mog 404's.
Not a lot of experience with them (yet :D) but I would say 37 if you made me answer...
it for sure depends on use....i run dana 44 axles on my cj5 with 42's and a 396 big block chevy engine...but i only use it for mudding..and i dont accellerate with the tires turned...
I run 40's (39.5's :rolleyes: ) with my front D44 with an OX and it hasnt even hinted at any problems. I think it has a lot to do with the kind of power you are going to put to it also. I still run my 4.0L HO and I dont think it has enough to damage it, but still goes where I want it to. Did Carnage Canyon, CO with out any issues.
I say 37's for rockcrawlin on a 44. I ran 36s on my front 44 with standard shafts and joints. Went through the my fair share of u-joints and outers. Switched to CTMs and cromoly shafts and never broke another shaft/joint. Stepped up to the 38.5s and started breaking hubs and ball joints. Bustin ball joints gets old real fast.
Since I put in the 60 I have had zero problems and anyone who has seen me wheel knows I occasionally like to get on the skinny pedal. :D
Despite the lure of 37s, I've decided to stick with the 35s. I keep going back to my original concept of when I started the build up. That the engine would be the weak link and everything else would have a good margin of strength, enough to handle 35s. This plan was designed so I should almost never have to worry about breaking something on the trail.
Would have already ordered my 35 MT/Rs, but they are on back order at most places (especially those with the cheapest price). However, they can get the 37s now so it was tempting to go with them.
Of course, I know I'll get on the trail later this year and wish I had the bigger tire. :D
dana 44
I run 35 bfgs mt kms on a scout dana 44 with a arb and a warn full floater, my fron is a wide track dan 30 with a trash lok and warn outed axles and internal splined hubs. In light of my front axle I take it easy on the stupid pedal but have never broke anything
Lots of Variables
I run the IRok 36 X 13:50 on the scout 44 in rear and dana 30 front with Warn axle shafts, so far, so good, but i also have plans to go with the 60/14 bolt combo. It depends on how you wheel and other factors like auto tranny? Gears in TC? etc... I would think that i am at my max right now, which is why i plan to go bigger.
Welp another not mentioned here is that Waggy and Scout 44's are half ton axles and have tappered shafts in them, while a 3/4 ton 44 has full shafts spline to spline and are stronger. At this point I dont have much of a worry about breaking shafts as mine is a 3/4 ton Dodge.
However Mike brings up a factor that I have not thought about and that is the ball joints. This could be a propblen I suppose but at the same time, that will be heavier in a 3/4 ton as well. I dunno we'll see as I'm for sure staying with bigger tires.
I have seen 42's being run on axles just like my 44 and they say they dont break them but have also heard plenty of guys with 42's on 60's and they break knuckles all the time... I think is a crap shoot each time you try hard to get over something no matter what axle you have. People told me that I couldnt wheel a stock 30 (with true trac) and a C-20 (with Summers Bros 1pc) on 37's with out breaking them, but I did and same thing with me, I wasnt afriad to use the gas pedal. They are now in another Jeep still going strong.
I just ordered some 37 MTRs from tires.com, they weren't on back order and ended up being 180 with free shipping. I desperately needed larger tires for better ground clearance with my rear 60 dragging thu the trail.
But 35s would probably be the safest thing
Leeland,
I'll tell ya though I ran my stock wide track axels with 37's but what I did was I used the 1.5 inch spacers all the way around and man it made a huge difference in how it did on the trail. Yes 3 inches wider is that big a difference and well worth it.
Not only that but I know where you can get them bought and shipped to you for 60 bucks cheaper than any one else advertises them for and yes they are top quality billet alum. They get advertised for $210 (a set=4) and up every where.
