Little LJ needs help
DixieFried
San Diego
CA
Ok guys and gals,
Here goes the "first post"
I recently bought my very own little LJ, love the thing and yes I have read the threads about the limited production runs, however I can't say this thing is worthy of being called a Jeep (yet) I'm thinkng at least a 3" and 33's, rock rails and new bumpers, but after that I'm stumped as far as what would really benefit the lil guy. So take a look at the picture tell me what I'm missing, With all the aftermarket stuff for jeeps I know theres something important I aint thinkin of...
first welcome & congrats on the LJ
If you like to wheel , I would recommend a long arm lift and what ever body protection you like or feel you need
you could go 5.5" & 35's like I have .
It does work really good
What to do to a Jeep, well alot of that depends on what you want to do with the Jeep. Personally my LJ only has a 2" spacer and eventually I'll add 31" ATs to it. I also plan to swap the 231 for a 242 once the warranty is gone. May consider a selectable locker at some point, but no real hard feelings there, already have the tracloc and that's good enough for what I really want. This is a daily driver and only occassional offroad vehicle.
Now my TJ is built alot bigger and all, but it is really overbuilt for what I like. When I only had 31" Tires, 2" lift, and a rear locker, I could do about 90% of the trails around here. I'd say that I can now do just about anything, but I still personally prefer the easier scenic drives to cool places over the "lets find the hardest obsticle" type of ride. The long arm is really nice and makes the TJ ride even better than stock (I'm up to 5" of lift with a 1" body lift, but still only run 32's as it's a 4 banger).
Just my .02
Robert
suggestion on building a jeep
I suggest building a jeep increamentally. It will make you a better driver. It will let you learn your limits and point out what you need to change. I am fairlly new to my LJ but like most of us on this board I have been in jeeping for a good long while. The first thing I did to my Rubicon LJ is add better skid plating for the gas tank, engine and steering box. These components are vulnerable to damage. Most clubs require tow hooks front and rear and a CB radio. Add unsticking gear such as a first aid kit a Hi lift jack, tools (shovel) and a strap. Join a club. Learn what a STOCK jeep will do. Then 33 to 35 and a long arm lift kit. But beware that 33-35 inch tires stress drivetrain components.
I kind of had the incremental aproach in mind, I'm really building this as a part time off-road DD, that was the reason for the 3" and 33's. I'm already working on the body, one of the bonuses of working in a shipyard, I want this to be built on the premise that is is still my primary mode of transport so I'm leaning away from the drastic mods as much as possible. One thing I found out is that after the body work with a 3" I should be sitting just low enough that I can get by with out adding a slip-yoke immediatly. (might need a sanity check on that but I'll cross that bridge once I get to it)
I just did the 2.5" heavy duty spring kit from Old Man Emu on my TJ.
It was really worth the cost. It now drives better than stock, and I got 2.5" lift out of it. And if I wanted too I could add a 1" body lift or spring spacers to get a little extra. But 4" is really as much as you want to get out of a short arm kit. At that point you really should be thinking long arms, and a SYE.
But 2.5" is a mice compromize and I think that 32's will go fine and possibly 33x10.50's. Currently I am running 31's and had no issue with stock suspension. So once I get new tires I will know better.
Carl
I kinda like smaller suspension idea, I've been playing the numbers and came up with this for a cost effective/really runable set-up,
2" Teraflex suspension lift
1" Body lift
Teraflex adjustable fron trac bar
Teraflex(Ok so I'm getting a good price on the TF kits) swaybar disconnects
Belly up skid plate
Homemade steering box, and gastank skid plates
Homemade rockrunners (4"x1/4"angle and 2" thick wall pipe)
33x1050R15 BFG MTR's
I'm liking this more becuase I shouldn't lose too much in my turn-radias, and I should still be able to get really nice articulation. Not to mention I'm gaining something around 6+ inches of ground clearence at the skidplate while keeping my center of gravity fairly low. And of course that I can do all this for about $1500 is a small incentive too. Lemme know if that sounds realistic or I'm just smokeing crack and should stick to building mud trucks. ;)
sound good BUT
I suggest a 3 inch suspention lift instead of a 1 inch body and a 2 inch lift. Based on my experence with body lifts I do not recommend them. BUt a 1 inch body lift is ok I guess. It has just been my experence that it was not worth the steering, clutch linkage, body mount cracking 10 years from now adjustments. I like the Idea of the belly up skid pan to get rid of "the shovel" but stronglly recommend a engine skid plate and a gas tanki skid plate also.
Might be looking at a SYE kit and new rear driveshaft... especially if you're lifting the t-case with the flat skidder. Vibes could be a real problem if this is a DD.
the only reason for the 1" is to get the belly-up on, and I'm going to wind up welding up an engine, tank and diff plates for it in the near future.
About the SYE, from talking to my buddy who runs the 4x shop's garage, with 2" suspension lift and new skidder on an LJ the drivehaft is long enough that I don't need to worry about vibes, however down the road I'm planning on upgrading to a 3-4" and will be adding it then, I'll have to see what she rolls like once I get this round of mods done and re-evaluate the SYE then.
Well the orig idea came back to huant me, I just got a super deal on a 4" Teraflex system so I bought it, still going with 33x10.50's but thats only so I can use the stock rims for now, I'll upgrade to full size tires once I can swing the flares and rims. Should have it on this weekend so I'll post pics once I get it up and running.
