Long term storage???
jag535s
CJ8-APT
Hey guys I need some advice, I'm off to the military and I am going to be storing my 8 for up to a year. OK so i change the oils and all fluids put stabil in the gas. is there anything else that will help make sure everything doesn't rot off if by chance it turns out to be longer? Should i unhook the battery or does it matter? what about tires should I drive it onto some 2x4 to keep them off the ground. I just last week finished repainting it. I've waxed the heck out of it. I'm kinda of worried about flat spots on the tires, since they are new with only 1000 miles or so on them??? I am storing it at my folks and told my dad to drive it once a month at least but i've got 4" lift he complians about being too hard to get into, which means he probably won't drive it. Any suggestions would be appreciated. thanx
1st off, good luck on your assignment and be safe if you are going into Iraq.
If you are storing the '8 inside, I would put it on stands to get weight off of the tires and for sure disconnect the battery. Also, even inside I would put some sort of lightweight cover (that breaths) on it to protect that new paint job.
You might even put the battery on a trickle charger that senses the charge and cycles on and off as needed.
I am sure others will chime in with things I have missed.
Get us an address where we can write you and keep up with you.
I know this board has several military folks that have had to leave country and we are all GREATLY appreciative of your sacrifices for us so we can play with jeeps and live like we do.
Good Luck and God Bless you.
hey jag...you can leave it at my house and i will start it once a week or so and keep everything exercised. I am in northeast arkansas. By the way I am making a serious offer.
I was going to suggest trying to find someone on here to leave it with... Scott beat me to it. :D Most of the regulars on this board have plenty of others that will vouch for them as solid folks that would be happy to help out.
I would put it on jackstands UNDER THE AXLES, you don't want to leave the suspension unloaded for all that time but keeping the tires off the ground would be a good idea.
I would unhook and remove the battery from the vehicle, just to be safe.
Indoors is obviously best, but a good quality cover would be a good idea if you have someone to pull it off and wash it every so often. Maybe stuff something in the tailpipe to keep anything from making a home up in it.
Good luck and be safe wherever it is you're headed.
jeep would be easy
Taking care of the jeep would be easy. A soldier from my reserve unit has been deployed since Jan...His 13 year old daughter has stayed with my wife and i and 2 daughters. Compared to those challenges ..babysitting a jeep would be gravy..:D
Strongly suggest the investment of Marvel Mystery Oil. After you take it for the last drive and get the engine warm, back it into where you plan on storing it. Take off the breather and start pouring some MMO into the carb, slowly at first increasing the amount. Just when you notice the engine starting to bog down, greatly increase the amount to make the engine die. Stop pouring when the engine has quit running. Would let it sit like that for six months without a thought. Next time it needs to be cranked up, pour a little gas in the carb and crank it up. The exhaust will smell very sweet, smoke for a few seconds, but the eingine will smooth out quickly. Unless he cranks it up and drives it for 20 miles or so to get everything warm and a chance to bake out the moisture, don't think it would be doing any more good than just letting it sit.
My family has done this every winter with our boat's V8. Sometimes it would sit for two or three years like that but it never failed. Pull it out, a little fresh gas and runs smooth as can be. We've been doing this for 35 years and have never had to touch the engine internals.
Also, don't worry too much. Last night I cranked up a deceased friends 1983 truck. It had been sitting in the garage for two years. Nothing was prepped for long term storage as when he parked it, he thought he was driving the next day. All we had to do to it was put a little gas in the carb. It was smoking pretty bad from the two year old gas, but ran nice and smooth.
Good luck on your adventure and thanks for help keeping my family safe.
thanks for the info. will greatly help. I've been putting everything away so i couldn't check the post for a while but, im squared away now and im going to get started on getting my 8 stored. As for those who want to store it for me, i got another friend that has an 8 as well, the one from missouri at the nationals with the olive drab and huge roll cage, plus we live close together (in front of nationals photo). Unfortunatly it will be outside, but it is under a carport next to my shed, so for the most part only a lil' eastern sun will hit it. I had heard about the marvel oil before but didn't know much about it. I assumed you just poured it into the gas and ran it thru...now I know how!! thanks all and thanks for the support. i leave 10/20. hopefully i can find a computer somewhere and check in.
