Looking at an '83 to buy
WillyT
Scramblered
chicagoish
IL
Evening!
I somehow found what is listed as a CJ-8 for sale that's under $1000. That alone makes me a little suspicious, but I've always wanted a Scrambler since I knew what CJ's were (I used to have a 7) so I intend to take a look at it.
THIS IS A NON RUNNING TRUCK NO JUICE TO THE STARTER V-8 360 MOTOR AUTO TRANS, BIG TIRES NEEDS SOME WORK
The back-half of the tub appears to have been removed and wood planking laid down in it's place. So right there means I would probably need a new tub. The doors are not original, he suspects they came off of a 7 (all this was done by the previous owner). Were the factory tubs a 1 piece unit? I've been looking around the fabulous landscape that is the internets and all I'm seeing are tubs that go from the firewall to the liftgate.
It has a 360, which must have been a transplant, because from what I've read, the only V8 option was the 304. That doesn't bother me too much, but it begs the question of what else is weird with it.
What should I be looking for when I eyeball this thing? I know the frames can rust out pretty bad, especially around the spring shackle mounting areas.
Looking for some :twocents: :D Thanks!
Tubs were and are one piece, and run about $5000 new for metal all said and done. Doesn't matter too much where the doors came from - CJ7, CJ8, YJ, they're all the same. Early 80's models came without vent windows, but that doesn't matter too much.
I wouldn't get too excited until I could lay eyes on it if I were you. Keep us posted, we'd be glad to help.
Right, that's right, we talked about that on JU. Sorry, my brain must have crossed some wires.
I'm going to try and take a look at this thing either tomorrow or Tuesday.
I looked at this a month and half ago its not running. The guy that cut the tub off did a nice??? job I guess its got wood planks mounted on the frame which looks also looks to be in rough shape, there is a lot of rot going on. The tires are too big they need spaces cause they are rubbing. The interior is a mess. I was thinking about it but I think you can find a better truck that you would not have to put so much time and money into.
I don't mind some hard work to get a decent running CJ. I work at a machine shop, and the engine I could rip through in probably a month. It's the body work that will set me back since I have absolutely no experience with it. But I'm willing to learn. I was expecting a new tub when looking at the pictures, and the toughest choice will be deciding between glass or steel.
The tires I would probably get rid of, as they're A) too big and B) look to be in pretty bad shape.
The biggest questions are if he's got a title for it (forgot to ask him that last week) and what kind of condition the frame is in. I'll hopefully know more in the next day or two, as it turns out I'm going to be close to that area for work anyways. Lucky me.
