WillyT
Scramblered
- chicagoish
- IL
Evening!
I somehow found what is listed as a CJ-8 for sale that's under $1000. That alone makes me a little suspicious, but I've always wanted a Scrambler since I knew what CJ's were (I used to have a 7) so I intend to take a look at it.
The back-half of the tub appears to have been removed and wood planking laid down in it's place. So right there means I would probably need a new tub. The doors are not original, he suspects they came off of a 7 (all this was done by the previous owner). Were the factory tubs a 1 piece unit? I've been looking around the fabulous landscape that is the internets and all I'm seeing are tubs that go from the firewall to the liftgate.
It has a 360, which must have been a transplant, because from what I've read, the only V8 option was the 304. That doesn't bother me too much, but it begs the question of what else is weird with it.
What should I be looking for when I eyeball this thing? I know the frames can rust out pretty bad, especially around the spring shackle mounting areas.
Looking for some
Thanks!
THIS IS A NON RUNNING TRUCK NO JUICE TO THE STARTER V-8 360 MOTOR AUTO TRANS, BIG TIRES NEEDS SOME WORK
Looking for some
Thanks!
