I've done some pretty extensive trips where 10-15 extra gallons were absolutely necessary and have tried several approaches, the traditional 5 gal cans are a PITA in some ways but also easier in others, the military types can be set back to back flat against the bulkhead, I usually install a tank there nowdays, or three of the plastic ones can sit abreast there. The key is to make sure thay are well secured and I think towards the center of the vehicle so the movement is minimal. On one trip I used three plastic cans and built som rails that clamped to the roll bar so I could use the space above the cans for lighter stuff, worked ok but when I need to get the cans I had to unpack the bed. Last time I used the single tank with the filler I could access without packing and used an electric fuel pump with alligator clips and a switch to pump it into the tank, more conveinent, to a point.
Whatever you decide, please post a pic
