looking for ideas jerry cans mounts
madjp62
albany
or
looking for ideas,where have you guys mounted your 5 gal gas cans in the bed? any thoughts
Jerry Cans
I once carried jerry cans. You need to decide how far at one time are you going to drive your rig. I found that I very rarely ran low on fuel. I didn't like the extra weight. I you think you are going to need more fuel, a small can of a gallon or two will probably be enough. Besides they take up alot of room and are a pain to load.
Just a thought.
Butch
I've done some pretty extensive trips where 10-15 extra gallons were absolutely necessary and have tried several approaches, the traditional 5 gal cans are a PITA in some ways but also easier in others, the military types can be set back to back flat against the bulkhead, I usually install a tank there nowdays, or three of the plastic ones can sit abreast there. The key is to make sure thay are well secured and I think towards the center of the vehicle so the movement is minimal. On one trip I used three plastic cans and built som rails that clamped to the roll bar so I could use the space above the cans for lighter stuff, worked ok but when I need to get the cans I had to unpack the bed. Last time I used the single tank with the filler I could access without packing and used an electric fuel pump with alligator clips and a switch to pump it into the tank, more conveinent, to a point.
Whatever you decide, please post a pic
yes,i need the extra
well last month when i took a scouting run i had to cut it short and turn back.better then the really long walk out. didnt see anyone else all day.
will post pic's when i decide.thx
I know it's a really old post, but what did you come up with? Can anyone else post some pics of what they came up with?
Patrick -
Did you see what Jeff did with his Gaucho build? The "T" style hitch, may be just the ticket....
Todd
I know everyone here has a working gas gauge and never gets too far from home...I like the compactness of the 1 gal rotopax ( http://www.rotopax.com ) , but I'm not enamored with the $50+ price. This is a creative bunch, someone must have some cool photos. I will take a look at the Gaucho build. BTW who is Patrick? I'm "Rusty" the guy who drives Scarmblers with no rust on them.
I'm running a Hemi in mine and sometimes I do need the extra gas. Calculating is important. I use the old style steel Jerry cans when I'm traveling and have plenty of plastic at the house. I don't like the plastic cans while driving because when they rub constantly they will build up static electricity and even wear through on extreme runs. The key to all this is to secure the cans as best as you can. The steel cans are quite cumbersome but much more forgiving. Just my opinion but it works for me.
