That would be great, both the pics and next years scramble.
I recently sold my CJ5 and have an 83 scrambler to replace it and my comanche with. My goal is to build a true dual purpose vehicle with an upper trail limit of Blanca Peak and a bias towards livibility on a daily basis. I want it as simple as possible and as reliable as possible. Right now the 83 is a 258 5 spd, I'm planning around 35s with an engine speed on the highway af 2500 ish rpm. Alcan Springs to clear, probably 4-5 inches with a front reverse shackle. I'm not sure if I will go 4.0 AW4, install a TF999, which I have already, behind the 258 and inject the existing six or try to do a 4.7 v8 with auto trans. Occasionally I think I'll just go to an AMC v8 'cause I know I can live with that performance, but then I remember the mileage and I go back to thinking 6. Rear will be a d44 from a scout II with a detroit, front will remain the D30, also with a Detroit most likely although I'm intrigued by some of the newer selectable lockers (not ARB). Gear ratio is undecided at this point, not likely to be lower than 4.27 nor higher than 3.73 but not sure which way to go. Half hard top, interior lining, new seats, tuffy console, AC and I should be good to go.
Of late though I've been thinking of going 3" with 33s and 3.73s, TF999 and inject the 258, cheaper and easier, more roadworthy as well most likely.
suggestions?
