Math
trust
PITA
White Rock
NM
does anyone remeber the formula for calculating engine speed given the axel ratio and tire size? I can't remeber it (big surprise) nor find it
thanks
tr
Terry,
This site should have what you need.
Gearing/MPH Calculators
BTW... I got the 35s mounted and on the 8 finally. Looks great. I'm working on the TJ flares right now. After I get that done I'll post some pics for everybody.
Thanks for the link, I'm building mine in my head right now with actual construction to begin when the title is resolved. Glad the tires worked out well for you I'd love to see som enew pics, I was checking your site the other day and really like the color. Plan for the San Juan Scramble next year, July 4ish, it's not that far
tr
I'll post some pics after my trip this weekend. I have the San Juan Scramble on my calender. I'm going to try to make it. I need to try to hook up w/ the other AZ people and see if they want to caravan up.
Let me know how yours comes together... What are you planning?
That would be great, both the pics and next years scramble.
I recently sold my CJ5 and have an 83 scrambler to replace it and my comanche with. My goal is to build a true dual purpose vehicle with an upper trail limit of Blanca Peak and a bias towards livibility on a daily basis. I want it as simple as possible and as reliable as possible. Right now the 83 is a 258 5 spd, I'm planning around 35s with an engine speed on the highway af 2500 ish rpm. Alcan Springs to clear, probably 4-5 inches with a front reverse shackle. I'm not sure if I will go 4.0 AW4, install a TF999, which I have already, behind the 258 and inject the existing six or try to do a 4.7 v8 with auto trans. Occasionally I think I'll just go to an AMC v8 'cause I know I can live with that performance, but then I remember the mileage and I go back to thinking 6. Rear will be a d44 from a scout II with a detroit, front will remain the D30, also with a Detroit most likely although I'm intrigued by some of the newer selectable lockers (not ARB). Gear ratio is undecided at this point, not likely to be lower than 4.27 nor higher than 3.73 but not sure which way to go. Half hard top, interior lining, new seats, tuffy console, AC and I should be good to go.
Of late though I've been thinking of going 3" with 33s and 3.73s, TF999 and inject the 258, cheaper and easier, more roadworthy as well most likely.
suggestions?
I think the best of what you've said would be to do the fuel injected 4.0 liter w/ the AW4. It keeps it simple and reliable. If you're going to keep it as a daily driver I would think the 3 inch lift w/ 33s would be the better option. My 8 w/ the 35s and the 4 inch susp lift and the 1 inch body lift is a little much to be jumping in and out of all the time. Perhaps throw in a 4:1 kit in the t-case and I would say you're good to go. A nice reliable vehicle that will have pretty decent offroad performance. Of course, going cheap also has its benefits... I seem to have forgotten how to do that... about the same time I bought the 8 I believe. :rolleyes:
