MC 2100 -slowly working on install- questions.
Yes it is needed for the TFI ignition, that's your ignition control module.
Here's an interesting link from someone that did both HEI and TFI:
http://keith.cj8.tripod.com/tfi_hei_comparison.htm
I replaced mine when I did the upgrade years ago, and the new one is leaking the potting out of it too.
Haven't noticed a problem, but it is only a matter of time when the electronics get exposed to the elements.
No idea what that tiny bit of explanation means, he could have botched the HEI install entirely or had a bad unit. For the utter simplicity and rave reviews all over the internet, the HEI wins every single time for me. Ditch a crap ton of wiring, the separate coil and that box for one simple wire and HEI.
Eric, do you have a part number or link ?
I like the TFI. I have the Ford coil mounted to the fenderwell, and the stock coil still mounted in the stock location. If a coil fails, plug in the other one and keep going. Have "stealth HEI" module installed (google that trooper and FLCJ) and an extra unit in the glove box. TFI doesn't require removing the distributor, and I can swap in spare parts really quickly if something goes awry.
Comparing swapping spare parts is relative, it's not like the module in an HEI is hard to get to at all, so we're comparing the ease of ordering fast food at Wendy's compared to McDonalds. I was on a mission to simplify the engine bay as much as possible and everything I saw was a complete toss-up in terms of performance and reliability between the two systems. Both are great upgrades. So the deciding factor for me was all of the extra wiring I could eliminate with the HEI.
Throw a spare module in the glove box and you're set.
Yes, you have to remove/reinstall the dizzy with the HEI, but again, we're not talking about hours of work and a little forethought when removing the stock unit makes it almost trivial.
Note that I did the HEI after having the experience of a bad factory splice/wire melt inside the stock wire loom that shorted 12V+ to the starter solenoid, activating the starter as I was driving down the road. Thankfully, I had switched to marine battery terminals with the wing nuts and was able to undo the positive battery feed once I got stopped and popped the hood.
That experience taught me to get rid of all possible factory wiring, hence the HEI call.
To an HEI? No. I bought a used one for $50 for the Postal and swapped the dizzy gear over to it. I just put a cheap Ebay unit in the 360 in Mater when the fancy-azz Mallory ignition that came with it crapped out. Reminds me that I still need to get a spare module for it...
Not really sure how to take your response. :shrug:
I was merely trying to answer his question.
As he already has the TFI upgrade and seems happy with it, I was linking to someone's opinion that actually did both. (There is more info on his experiences as well, that was the most pertinent concise post)
Doesn't seem like the time or money to change to HEI is worth it if he is happy with what he has.
I personally couldn't care less what he runs on his Jeep, just trying to help him save funds for other purposeful upgrades.:thumbsup:
Thanks for the info wm69.
I'll check into that later. :wave:
I didn't know he had a TFI already, I missed that reading through too fast, sorry. I saw mention of the AMC ignition box having problems and was responding as if you were suggesting a TFI over a HEI to someone without either.
I am going to ask a dumb question- ignition systems have always been hard for me to understand... Based on what I am reading and a quick google search, TFI is the same thing as the "Team Rush Upgrade" (Larger cap, rotor, wires, etc.), correct? I did this upgrade minus the coil (still running stock) a while back. I did not change out the ignition module located on the drivers side fender well. I understand that the nutter is basically a bypass that lets the ignition module connect directly to the distributor without the computer having any input or effect on the timing. In an HEI setup is there still an ignition module?
On the stock HEI system the distributor contains the ignition module inside the distributor (under the cap) and the coil is mounted in the cap.
As BW stated, this reduces a lot of external wiring since the components are all integrated in the distributor.
The "stealth HEI" that wm69 referred to replaces the factory Jeep/Ford fender mounted module with the GM HEI module. It is still external of the distributor.
Ignition systems can be super complicated in terminology. I'll take what FLC started a step further.
For clarity, the stock Jeep ignition system is the Duraspark II that Ford used from 60s to early 80s. The module on the driver fender (same as HEI module like FLC said) turns spark on/off and controls spark dwell (how long it is on).
Both systems have the same parts and work the same way. They are just packaged differently in installation. So if you had a meltdown in your harness like BW did, it would be silly to put back all that wiring for the same inductive discharge type ignition. But without a meltdown, you can make the stock system work just as well as an HEI using newer parts.
Here is what the upgrades folks are talking about on the stock system do, and why.
- E-core coil - some folks are calling this TFI, but its not. TFI is a control and feedback module used by Ford in computer controlled EFI applications when they went away from Duraspark (they went from inductive to capacitive discharge ignition systems)
- What E-core coil does - it allows you to run a full 12v to your coil without cooking it. It lets you eliminate the resistor wire (part of nutter process) that acted like a ballast resistor for the stock coil. So your coil has a higher voltage/amperage (ie. hotter spark) potential than it did before.
- Larger cap and rotor - Spacing out the plug wires in a larger circle makes it harder for the higher voltage/amperage being sent from the e-core coil to cross fire inside the distributor cap.
- Larger plug wires - this is just a step up in wire technology. Lower resistance inside and better insulation outside makes them work better.
- Higher heat range plugs - Here is one most folks dont take advantage of. Hotter spark means you can run hotter plugs with a wider gap. Probably not much gain on a 258, but maybe on a 304 or 360.
The trouble with Duraspark II these days, is there is little support for it. I havent looked in a while, but last i did there was nobody making new control modules. They were all re-manufactured.
Whereas you can find a spanking new HEI assembly for just about anything you want one for.
Bonus info - The computer used with the Carter BBD and the Duraspark ignition was step one of moving to TFI ignition and fuel injection on AMC motors. The computer AMC was using, and we find and bypass in Jeeps, was the same as the one Ford eventually used to run EFI fuel control with TFI ignition in everything until they went to DIS and then coil on plug systems.
HEI is definitely much cleaner.
Both are probably equal in performance. The TFI is the same as the Team Rush. TFI uses off the shelf parts, and by the time the HEI distributors became available I was already running the TFI setup and have spares on the shelf so I stuck with it.
When the HEI setups first came out there were a lot of problems with (IIRC) brittle or hardened distributor gears that would really mess things up if you didn't swap a good distributor gear on prior to installing the unit.
I ran a Jacobs for a long time on my tan CJ. There was no perceivable difference in the $400ish Jacobs setup I was running vs the $100ish TFI setup I installed on my green CJ. The Jacobs bit the dust and, having been happy with the TFI setup, I just did that on the tan Jeep too.
TFI uses parts that are easily found at any auto parts store. Living in the boonies like I do that was another big positive. Of course, I'm such a parts hoarder now that I have pretty much spare everything at the house now, but that wasn't always the case.
The replacement Ford style aftermarket duraspark ignition modules are junk nowadays, but you can install a GM/ HEI style module and it will work fine with the rest of the "team rush" aka TFI upgrade.
Does the E-core coil eliminate the need to nutter? Since I have done all of the Team Rush upgrade except the coil, I think I am going to stick with what I have done and replace the coil. If the nutter is still required with the new coil- do the nutter or coil first? or does it matter? Anyone have a good link to detailed step by step instructions for the coil?
Josh - You would only need to nutter bypass if your Jeep had the computer controlled carb and ignition. If it did not or if it is removed already by a previous owner, there is nothing to bypass.
The two "upgrades" to stock that are talked about in this thread have 2 different purposes.
"Team Rush" - is the large cap/rotor and wire upgrade to the stock distributor. Just changing those parts can make a big difference in how well your engine runs as it really cleans up the energy path for each spark charge delivery. Changing your coil to go along with this is optional, but can provide further improvement. This upgrade has nothing to do with the the nutter bypass.
"nutter bypass" - This is the operation by which you bypass the stock computer in your ignition circuit. In this procedure you change the route of the purple and orange wires that come from your ignition box on the driver fender. In stock form they run from the ignition box to the ECU and then from ECU to distributor. You change the wires so they run from the ignition box straight to the matching wires on the distributor harness. This removes any artificial adjustment the ECU might make to spark signals based on sensors that may or may not still be functioning on your engine. No impact to coil, cap, rotor or any other physical parts or thier function in the ignition system.
My jeep is an 85 and has the computer. It was basicallly stock (and running like a turd when I started all this). The recent mc2100 installation took the carb out of the computers domain. All the computer is doing now is maybe interfering with the timing/ ignition. I know the nutter is my next step to eliminate the computer entirely. I was confused and thought maybe going to an e-coil might eliminate the need to nutter. Sounds like that is not the case.
Yeah do the nutter. You don't want that computer messing with ANYTHING, so just eliminate it from the equation and then you don't have to wonder whether or not it's messing with your ignition or timing.
