- Bedford
- NH
Nothing wrong with Plum Crazy Purple, my `Cuda will be a shade of it, not exact, but pretty close.
I have a full cage that'll be going in, bolted thru to the floor. I want to run 4 Acura NSX seats, so I need the width. All 4 seats will have 4 point harnesses too. Want my kids comfortable over a day of wheeling!
I have a question for you. On pic #4 you have the floor frame (upper floor) spot welded to the side wall of the tub before and rear of the wheel well but don't have a piece (of 1' x 1' tube) going down to the lower floor frame (where body mount is). I know if you weld the floor plating to the floor frame it will strengthen it but without the piece going down to the lower frame do you think in hard core wheeling the body will flex and either pull that loose or bend the skin?. Not knit picking (you know more and can do more than I ever can) was just curious (learning experience for me). Thanks and the jeeps incredible. Can't wait to see completed.![]()
The CJ 8 body is now mounted to the JKU frame. Time to weld in the new floor, and then get the drivetrain into her. We're going to build a removable tranny tunnel once it's all in. And my boys are both hounding me to paint it plum crazy purple.
4 NSX seats? Wow. Are those readily available? I bet everyone will be comfortable in those.
Sorry!! I'd meant to address that!! She's 10 gauge steel, a little thinner than 1/8", and I'm definitely looking at how to make the gate line up with the floor!! We've got the tub as low as we can, without cutting frame crossmembers, but the tailgates still lower than the floor. I'll shoot a pic
