Scott Mine
- Arnaudville
- LA
Tranny Update
He is my tranny update that i got from the shop.
The torque converter bolts were too long which inturn punched through the converter breaking some of the internals. Which started breaking apart and going into the tranny which inturn started clogging the ports and holes internally which restricted the flow through the tranny which made it over heat and burn up.
So back to the beginning. I knew this had happened with the torque converter bolts and talked some people about this and they said it would not harm anything. So i went back with it. So for future references do not reuse the converter if this has happened to you. I learned my lesson for sure. I just am thankful that my junk did not break while on the trail and had to be towed out. I only had to be towed down the road.
