Model 20 axle questions
ddavis
KS
I am looking to upgrade my model 20 rear axle with one piece axles. Which manufacturer is recomended; Mosier, Superior, Alloy, or some other? This Jeep will see moderate off-road use at the most.:shrug:
I can't tell you which ones to use, but be sure to stitch weld the tubes to the differential housing. 3 1" welds on each side will do the job. Do one 1" weld at a time. letting it cool before doing the next one on the same side. Place a welding glove or something over each weld, so they cool as slowly as possible; this reduces the chance of the metal turning brittle; for the best results possible.
I've seen too many 20's spin the tube in the housing, to not do this.
Thanks John, I will be sure to do the welding while I have the axle out of the Jeep. Does anyone else have any advise on which one piece axles to purchase? Any input would be appreciated.
We have installed both Alloy and Genuine Gear kits. Pretty well satisfied with both.
I have another Alloy set awaiting install on a Scrambler.
Alloy has the 10 year warranty. I'm confused by Superior's warranty. Yukon is crap.
One Piece Axle Install
Just be advised that the one piece axle install is not something easy to do in your driveway. You need to seperate the old axle / backing plate to reuse it then press the new bearing and retainer on. The hardest part is cutting down the spacer to the proper thickness. The spacer determines the amount that the new style bearing sticks out of the housing. I think .020 to .060 is the spec. The left and right spacers must be machined perfectly square since the bearing race mounts against it. The manufacturers do this to make up for the variation in width of the housings due to production tolerances. I have done lots of them, but I remember the first time I had questions.
dd... My choice was to keep the 20 alive too. I like the ring gear strength but them axles do suck. The weld broke and spun on me one day and had to limp home in front wheel. How embarassing that was.
Anyways, I chose the WARN full floater with disk brakes. Have not seen it advertised in a while but if you find one, it converts to rear disk brakes. A liitle bit of work but it was worth it. By the way, full floater just means the axle has splines on each end and the wheel has bearings like the front hubs. In fact, I got the hub option for easy towing. http://www.hoodlift.com/reviews/warn_fullfloater.html
Not for everyone but has worked well for me, so far. :)
I would really like to go the full floater route if it just wasn't so expensive. I just don't think that I would get the result that I want with the amount of money that I am willing to spend. This Jeep spends 90% of its time on the street, so the one piece axles should do what I need.
I really appreciate everyone's responses.
Thanks
I used the Mosier axles they worked good if you need install picks let me know. The instructions could have been a little more detailed.
Just for laughs the wrong way to install bearings
Heating it up on the wood stove to about 180
And 1 1/4 galvanised pipe from home depot to install
I would guess these will last under 15k Miles
I have been looking on the internet for the installation instruction for one of these one piece axle manufacturers. I haven't been able to find any. Your installation pics would be great.
Thanks
FYI... WARN does NOT make the full floater kit anymore. I was looking into that last month and here's the email response I received:
Warn Customer Service said:
Support: Question about Warn Part Number: 36655 (Rear Full Floater Hub Lock; Standard Duty; Set; 30 Spline; Replacement; Internal)Wednesday, October 15, 2008 3:57 PM
Jim,
Up until about three years ago we offered a full float axle kit that would convert the factory axle from semi float to full float. This kit would include new spindles, wheel hubs, bearings, seals, axle shafts and hublocks. The 36655 part number is just the replacement hublocks for this kit. Although these kits are no longer in production we continue to list the replacement hublock part numbers on our website for those who have the kit installed and are in need of new/replacement hublocks.
The short answer would be that the 36655 alone will not work without having previously installed a full float kit.
Todd Wright
Technical Service Representative
Warn Industries
800.543.9276 phone
503.722.3000 fax
so much for that idea...
Oh well, at least they keep the parts handi.
and Thanks, Jim. I made a copy of the phone numbers and email for the service guy.
Thanks for the info. I also have a Warn Full floater kit (on the shelf right now) I was happy with it and only pulled it because I sold the Jeep.
Usage?
Not sure what size tire and what your usage will be off-road, but you mentioned 90% on road. Maybe consider just sticking to the 2 piece axles?
While I don't love the 20, I ran a stock 20 w/3.54 gears and a lock-right locker in a CJ-7 w/32X11.50-15 BFG and Good Year MTs for years w/o any breakage behind a pretty healthy 401. My wheeling was a mixture of sand, snow, mud and some rocks.
Assembly is crucial to make them live though, the axle taper and spline need to be in good shape and VERY CLEAN. Same goes for the hub. The torque spec for the axle nut is 250 ft-lb and tighten more to line up the castle head nut w/the hole for the cotter pin. No gaurantees...you can break anything, but it does help.
Good Luck w/whatever you decide!
My 2 cents is to keep the '20' as well. In fact...as long as you have your welder out to strengthen your axle tubes, weld the axles while you are at it. **poof** 1 piece axles! There are a variety of reasons NOT to do this, but in the interest of having a heavy duty set of axles on the cheap, this is certainly 1 way to do it. The obvious down side is that you will shift the "weakest link" from the axle key to the ring gear or something else expensive. This is also true if you install 1 piece axles. So, 1 guys opinion.
Todd
