Moser instructions anyone?
Alaskan Postal nutjob
FORUM MANAGER
Anyone got instructions for Moser 1-pc axles sitting around that they could scan? I picked up a set used and want to know that I do the right process to install them.
I was reading something about removing a thrust spacer in the carrier???
All I need is the part after pressing on the bearing and retainer, since that's already done.
Any other words of wisdom?
I'm also trying to stop my rear axle from leaking at the same time... WHEEE!!!
Hey Eric,
I had the instructions out in the barn and didn't think about them. When I get back from the beach I'll look for them. I'm usually good about keeping up with things like that (learned from experience). I know I recycled the box but not sure where the directions are.
I really, really hope you don't go through the trouble to change them and still have a leak like I did. Of course you shouldn't have nearly the expense that i did.
It will probably be Wednesday since I'm leaving in about 30 minutes for the beach.
Robert
I've got two. But it's wierd. One sheet says remove outer seal, one sheet says don't. And my used ones came one with and one without. Also, my instructions are for the sealed bearings. Now they use a tapered bearing. Moser said they would send me directions for converting my axles to the new bearings. But they do still sell the old ones. I guess you won't need those spares anymore. I'll have to see if I still have it on my computer.
I don't have a scanner, but I can fax you the directions I have, I just put a set in this spring. The spacer removal was a suggestion on my kit, not a requirement, so I tried it without removing anything and it seems to work fine. No problems so far!
I checked the barn today and didn't see the instructions. They must have been in the box with the shafts when I took it to the shop and they must have tossed them,. I thought I brought them home with me but I guess not. Sorry.
