muding in maine
jepnzgrl
augusta
me
New to us an 85 scrambler 6cl std w/cruze 112000miles needs some love to get back to normal.
We never had a Jeep, are very mechanical with a complete shop.
Windshield broken, headlights don’t work-most everything else does or seems to.
Rt Front hub missing; 5 bolt I believe I need an M253 the left has a 2 & 4 on it
Ignition has been switched to points, would like to go with something electronic?
Air cleaner is rusted and broken; all vac lines are a mess. I have the schematics from this site
Stock roof is replaced with a reg CJ hard top and a trunk-hand made
Runs and drives ok for something that’s sucking cold air and had a past life as a hunt camp plow buggy. The body and frame look very good, it was white-painted light blue some time ago. I’ve removed the plow and put it on the tractor.
What would you do? this is not for sale, we would like to use it as DD third vehicle for three seasons starting mud season=1/3 mile, 5 weeks of bottomless muck and slop on our road in the spring. It not for sale, and will stay in the family for a long time.
Welcome :wave:
Not sure quite what you're looking for in response. I'd start with all the safety pieces: steering, braking, seats/belts, windshield.
Is your windshield frame good? If not, don't bother putting good glass in it, get a replacement and use that.
I'd check and replace all the fluids, look for seal issues.
Fix the hub issue, not sure what an M253 is. CJ hubs are easy to come by.
Replace the carb with a Weber or Motorcraft 2100. Lots of how-tos out there. Not sure about the points thing, should have a regular distributor, you can replace with an HEI or upgrade to a TFI setup and that, with the carb, would let you get rid of most of the vacuum lines.
After that, go through whatever else in you own priority order.
That help?
Pictures of what you're starting with would be most helpful too ;)
Welcome !!!
I was born in Dover fox-croft Maine , near abbot, Exeter , and dexter
Are you near any of these ??
thanks for the reply I'm originaly from Gladwin
the frame seems good around the window wont know for sure untill I find a new one
cant find a used 5 bolt hub -all 6 bolt this is stoping us from driving it, do we bite the bullet and but two new ones? its the auto part stores best deal
I'm thinking keep things stock as possible, is this crazy?
what will the other carbs do for me?
is there a good book for referance?
I will have a set of 5 bolt hubs shortly, I just have to get them off the axle.
Not sure if you get down to Southern NH anytime, but you look to be 3 hours away or so... it probably wouldn't be too much to put them in a small box and ship.
The curious part I have is the points setup... if you have an 85, switching back to points seems interesting... are you sure the front axle is Jeep too... a Dana 30? I just want to make sure because the hubs I have are coming off a wide trak Dana 30.
PS> I also have a windshield frame that is a little rusty on the bottom, but the glass is good, you might be interested in that too.
I only mentioned swapping the carb because you mentioned that the vacuum lines were a mess and you were looking to change the ignition. If you do both the ignition and the carb, you can eliminate a TON of wiring under the hood along with nearly all of the vacuum line.
You can make the stock carb work, but it's not worth the effort if you're not going for a full restoration where you're going to put all the vacuum back on.
CertifiableJeep
How much and how do we do this?
We are walking in and out now, my one ton bottomed out we can't wait to get this going, probably one more week of mud.
