My 82 Build
dmorolli
Sterling Heights
I posted pic months ago of my barn find, body and frame were destroyed. IMG_0789.JPGIMG_0790.JPG
I have another tub and frame, tub needed new floor DONE! Moving on to frame, not too bad. Need a few repairs.imagejpeg_0.jpg
I also replaced the rear floor riser.
On to the frame.
That replacement floor looks awesome.
I was on the fence about repairing floor or replacing, so glad i cut it out and replaced.
It is an omix ada panel and actually fit very well, minor adjustments.
It looks like you may be at the point i was at with my 81 restoration. I could have bought a new tub just as cheap as fixing my old one with a lot less labor.
Finished up my frame repair today, had some rot around the rear hangers. I made some 1/4 inch plates with a piece if 1 1/2 flat stock welded to bottom of frame, mocked it up and welded them together before installing on frame.
I also installed 2 1/2 spring hangers on the front because I am using YJ springs with a 4 inch lift.
Finally got my scrambler fired up! The 4.0 purrs,managed to find a 5 speed for it also.IMG_1113.JPG
Time to start final assembly, ended up pulling tub to install brake and fuel lines.
